regularman Posted April 22, 2007 Share Posted April 22, 2007 I mean that particular issue seems to plague subies and I would like to know everyones tips tricks and failures. Remember when filling the radiator with coolant to throw a cap full over your shoulder as tribute to the head gasket spirits I would imagine this would be a good discussion topic. Some say use only subaru gaskets, but others have had good luck with other brands. Some say use a 3 piece steel gasket. My car originally had the ea82 turbo, but blew 3 headgaskets on the turbo side and the motor had a crank problem. so I rebuilt an ea81 and that lasted 3k miles and the crank went because I didn't install a new oil pump. Now do I rebuild the ea81 again or buy another ea82turbo that I found with a blown headgsket and try putting it back original again? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 22, 2007 Share Posted April 22, 2007 HG's aren't that big of an issue - they last just about as long as any other brand out there ~200,000 give or take if you take care of the cooling system. If you are repeatedly blowing them then there's some problem with the head, block or cooling system, you haven't got them installed correctly or they aren't quality gaskets. Running higher boost on the turbo's will do it also. GD Link to comment Share on other sites More sharing options...
regularman Posted April 22, 2007 Author Share Posted April 22, 2007 HG's aren't that big of an issue - they last just about as long as any other brand out there ~200,000 give or take if you take care of the cooling system. If you are repeatedly blowing them then there's some problem with the head, block or cooling system, you haven't got them installed correctly or they aren't quality gaskets. Running higher boost on the turbo's will do it also. GD I'm thinking of going back with the ea82 engine out of the wagon for 250 bucks. What I hate about this is its my dads car and he doesn't really have the money for trial and error. Right now I have two engines torn completely apart in my garage and nothing to work with. Who makes the best head gaskets for the EA82 turbo? Link to comment Share on other sites More sharing options...
Caboobaroo Posted April 23, 2007 Share Posted April 23, 2007 I'm thinking of going back with the ea82 engine out of the wagon for 250 bucks. What I hate about this is its my dads car and he doesn't really have the money for trial and error. Right now I have two engines torn completely apart in my garage and nothing to work with. Who makes the best head gaskets for the EA82 turbo? OEM Subaru headgaskets for the EA82T. A little more expensive (I've paid anywhere from $50-$75 for them) but they hold up better to the boost of the turbo. If it was NA, Fel-Pro gaskets work just as good. Link to comment Share on other sites More sharing options...
daeron Posted April 23, 2007 Share Posted April 23, 2007 doesnt RAM engines sell a high performance headgasket for the EA82? Naturally, this would be even pricier than the SOA part, but probably worth it. Link to comment Share on other sites More sharing options...
subeman90 Posted April 24, 2007 Share Posted April 24, 2007 You give me a well written write-up on HG repairs and pertanent info and you can be famous and well loved for contributing to the USRM. I am not the know-it-all God of the subaru world so that is why we take "user submissions" ..and take pics too while you are doing your work. Link to comment Share on other sites More sharing options...
