crazy D Posted April 23, 2007 Share Posted April 23, 2007 what type of metal are Ea81 front hubs made out of nad are the cast or forged ? redrill to six lug and metals teacher recommends re-enforcing:) Link to comment Share on other sites More sharing options...
subie_newbie Posted April 23, 2007 Share Posted April 23, 2007 The hubs are cast iron. While the re-drilling process does 'weaken' the hub, I'd bet you can ask around and no one's had one fail from the drillings. The casting is pretty soft and I'd imagine you'd bend one before you'd crack it across one of the new or empty holes. Someone with a CAD system could easily do a FEA on it. Any bored drafters around? Link to comment Share on other sites More sharing options...
crazy D Posted April 23, 2007 Author Share Posted April 23, 2007 oh ok cool Link to comment Share on other sites More sharing options...
Phizinza Posted April 24, 2007 Share Posted April 24, 2007 I think reinforcing is just over doing it. It is a good idea to grind the back of the hub where the new studs go in so they sit flat and then weld the studs in. I have a feeling welding more metal on will run the risk of unbalancing them and or softening them from the heat of the weld... I have never heard of one fail after being converted. Although Jibs (your related to him right?) had his new studs strip on him or something like that, but I used old studs from other hubs and they are fine. Oh, but one of my new wheel nuts stripped ( they are cheapies.) Link to comment Share on other sites More sharing options...
