hatchsub Posted April 24, 2007 Share Posted April 24, 2007 Do you guys think i could get away with unbolting one bolt on my intake manifold to take off the air cleaner mount and then bolting it back down without disturbing the gasket? There is also an emissions things that im going to want to do the same thing to. I guess my question is can i get away with unbolting one bolt per side without affecting my intake gasket seal? Link to comment Share on other sites More sharing options...
pisces_0 Posted April 24, 2007 Share Posted April 24, 2007 hatchsub said: I guess my question is can i get away with unbolting one bolt per side without affecting my intake gasket seal? Probably not. I broke one off while trying to do that exact same thing (remove manifold bolt, take off a bracket & replace manifold bolt) and had a consistent coolant leak at the manifold gasket until I replaced the broken bolt and replaced the gaskets. In short, leave the manifold sealed if you don't have any current leaks in it. Link to comment Share on other sites More sharing options...
Gloyale Posted April 24, 2007 Share Posted April 24, 2007 I'd have to disagree with pisces_0. I have removed just one of the bolts before for access to something(I forget what) but I've done it several occasions. As long as you don't break the bolt. Some are really rusty and prone to breaking, but most I've seen just come right out after. I would resnug all of them when done. I have never had an intake manifold leak, from doing this or otherwise. Link to comment Share on other sites More sharing options...
daeron Posted April 25, 2007 Share Posted April 25, 2007 Removing one bolt from the intake manifold SHOULD not disturb the seal at all. IF, however, that bolt presents difficulty, then you are liable to have more problems. That is the conclusion to be drawn here. Give the bolt a shot. Unless the bracket in question is somehow configured such that IT disturbs the gasket (it IS on top of the manifold, right?) then as long as the bolt breaks loose easily, you are golden. Link to comment Share on other sites More sharing options...
Phizinza Posted April 25, 2007 Share Posted April 25, 2007 I've taken all the bolts out and put them back in with no problems before. But that doesn't mean it will always work like that.. I'd say you'd be alright if you just removed 1 bolt and put it back in soon after. Link to comment Share on other sites More sharing options...
