Gloyale Posted April 24, 2007 Share Posted April 24, 2007 So I need to replace my front Right(pass) knuckle. The casting broke down at the pinch bolt for the Balljoint. The unthreaded *tab* just cracked off, maybe I pryed it open a bit too far and cracked it. Then when bolting it back down tight it just snapped off. Becuase of the recess for the bolt in the Balljoint, it still bolted down tight and acheived some clamping action, but I do not want to drive on it any more than I have too til I get a new knuckle. What years and models interchange? I'm thinking any 1st gen(89-94) Legacy would work. Is there any difference between Sedan, Wagon, Turbo etc? Also what about 95-99 non-outback Legacies? What about Outbacks? What about imprezas? I need to know what I can use from a J-yard. Unless someone here has one they want to ship me? Quote Link to comment Share on other sites More sharing options...
lmdew Posted April 25, 2007 Share Posted April 25, 2007 If you have ABS, then you will need a like knuckle. I may have one. Larry Quote Link to comment Share on other sites More sharing options...
john in KY Posted April 25, 2007 Share Posted April 25, 2007 Think everything you lised will interchange except FWD Impreza. Quote Link to comment Share on other sites More sharing options...
jamal Posted April 25, 2007 Share Posted April 25, 2007 a fwd impreza knuckle will swap over too. In fact, any impreza, legacy, forester, or outback knuckle will work except for 05+ sti parts. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted April 25, 2007 Share Posted April 25, 2007 28012AA014 Legacy 1990-1999 HOUSING, FRONT AXLE LEFT SIDE FOR ALL 1990-1999 LEGACYS Other models listed with the same part no 28012AA014 Forester 1998-2000 Impreza 1993-1999 Outback 1995-1999 Got the info here. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 26, 2007 Author Share Posted April 26, 2007 j-yard close to here has a 91 legacy wagon. 2WD. Guy say's his interchange tell's him no fit. I can't see how that would be? He might have a loyale back there and be getting confused? Quote Link to comment Share on other sites More sharing options...
jamal Posted April 26, 2007 Share Posted April 26, 2007 his interchange thing is wrong if it's really a 91 legacy. Rear 2wd knuckles obviously won't exchange but the front will. You should the newest one you can find though. The bearing in my junkyard knuckle lasted less than a year before I had to have the bearing and hub replaced. If you have abs I think the tone rings are in different places on different cars but you mightd be able to take your old one off and put it in the right place on the new part. Quote Link to comment Share on other sites More sharing options...
lmdew Posted April 27, 2007 Share Posted April 27, 2007 I have the Drivers side front hub for you. It has the spot for the ABS sensor if you need it and the ABS sensor ring on it + the ball joint. I can ship it out Friday if you get back to me. PM Sent Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 5, 2007 Author Share Posted May 5, 2007 I have the Drivers side front hub for you. It has the spot for the ABS sensor if you need it and the ABS sensor ring on it + the ball joint. I can ship it out Friday if you get back to me. PM Sent DaMN!! I mistated in my orginal post. Edited in red but I need the passsenger side. I hope you have one cause I just sent you a paypal! Let me know if you don't have a right(pass) side one. Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 5, 2007 Share Posted May 5, 2007 PM you. Larry Quote Link to comment Share on other sites More sharing options...
