crockettbrat Posted April 26, 2007 Share Posted April 26, 2007 I just got my lift kit in the mail. The brat is movin' on up! Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted April 26, 2007 Share Posted April 26, 2007 What kit did you go with? Quote Link to comment Share on other sites More sharing options...
crockettbrat Posted April 26, 2007 Author Share Posted April 26, 2007 What kit did you go with? I went with the SJR lift. It looks beautiful! My new shocks should arrive any day, and then I'll get started. Quote Link to comment Share on other sites More sharing options...
northguy Posted April 26, 2007 Share Posted April 26, 2007 Go buy some rust penetrant and let it soak in for a couple of days while you're waiting. Quote Link to comment Share on other sites More sharing options...
crockettbrat Posted April 26, 2007 Author Share Posted April 26, 2007 Go buy some rust penetrant and let it soak in for a couple of days while you're waiting. Thanks for the tip. So far everything I've done to this vehicle has been smooth regarding crusty rusty stuff. I wish I could say the same for my bmw 2002. I want to roll that rusty lump into the ocean. Quote Link to comment Share on other sites More sharing options...
LiftedEA81 Posted April 26, 2007 Share Posted April 26, 2007 Yes, go get PB Blaster. It will make the job 1000x easier. The bolts you will be removing have been under your car for 20 years, subject to all kinds of nasty road grime. If you strip one of the threads while removing the bolt, you will fight it when you gotta install the block. The 1st time I did a lift install, i had to use a tap to chase some of the threads in the body so the bolts would hold. Quote Link to comment Share on other sites More sharing options...
daeron Posted April 26, 2007 Share Posted April 26, 2007 sea foam deep creep leaves PB Blaster in the dust. Just like PB Blaster did to WD-40 when it came out. Sea Foam Deep Creep really is that much better, IMO. it COSTS more, to be sure, but so did Blast when it came out.. and the deep creep just eats rust for a light snack. it doesnt go away over time; I have taken frozen diagonal cutters, freed them up with deep creep, (they felt like NEW) and left them outside under a canopy for like, eight months, picked them up and when I moved the pliers back and forth a couple of times, deep creep started seeping out of the box joint... and they still felt like new. PB Blaster, I can get the same results, short term.. but in a month the pliers are sticky and rusty again. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted April 26, 2007 Share Posted April 26, 2007 When installing the new bolts with the lift kit use some anti seize or something on them... Nothing worse then trying to take out a bolt later on and it shearing on you. Quote Link to comment Share on other sites More sharing options...
