carfreak85 Posted April 26, 2007 Share Posted April 26, 2007 Does anyone have pics/ a write up on how to reclock the torsion bars on an EA81? I want to lower mine, but I'm not sure how to go about it. Link to comment Share on other sites More sharing options...
carfreak85 Posted April 29, 2007 Author Share Posted April 29, 2007 Bump! Link to comment Share on other sites More sharing options...
Caboobaroo Posted April 29, 2007 Share Posted April 29, 2007 I'm not sure on EA81s but I know on the gen 1's when you reclock the rear torsion bars is actually pretty easy. I had to jack the car up, pull the rear wheels off, and on either side at the outside ends of the torsion bar tubes, was a 12mm bolt, loosen that up, then I took an air hammer and pounded the torsion bars out from the inside. Then spin it to where I wanted it, pounded them back in, stuff the bolt back in, slide the wheels on and done. Don't see why an EA81 would really be any different though. Link to comment Share on other sites More sharing options...
carfreak85 Posted April 30, 2007 Author Share Posted April 30, 2007 Hmmmmm, I'll have to take a look at that today after my chemistry lab. Did you re-clock the torsion bar or the semi-trailing arms? Did you notice a difference in spring rate or ride quality? Also, how much did it lower the car overall? Link to comment Share on other sites More sharing options...
mikeshoup Posted April 30, 2007 Share Posted April 30, 2007 carfreak85 said: Hmmmmm, I'll have to take a look at that today after my chemistry lab. Did you re-clock the torsion bar or the semi-trailing arms? Did you notice a difference in spring rate or ride quality? Also, how much did it lower the car overall? When you do this, take pictures. I wanna fix my wagon's rump roast end being stuck up in the air. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted April 30, 2007 Share Posted April 30, 2007 don't ea81s have a special hieght adjustment bolt on a lever in the middle of the crossmember containing the torstion bars? As far as I know u just go under the car and crank this bolt and it adjusts ride height.. Link to comment Share on other sites More sharing options...
Gloyale Posted April 30, 2007 Share Posted April 30, 2007 PoorManzImpreza said: don't ea81s have a special hieght adjustment bolt on a lever in the middle of the crossmember containing the torstion bars? As far as I know u just go under the car and crank this bolt and it adjusts ride height.. Actually, this bolt is accessed through a hole in the floor pan, under rear seat. No need to get under car. OP may want to lower more than can be achieved with this bolt. Link to comment Share on other sites More sharing options...
carfreak85 Posted April 30, 2007 Author Share Posted April 30, 2007 PoorManzImpreza said: don't ea81s have a special hieght adjustment bolt on a lever in the middle of the crossmember containing the torstion bars? As far as I know u just go under the car and crank this bolt and it adjusts ride height.. If the car is too low after clocking the semi-trailing arms then I will use this to adjust it back up. I will fully document the swap, but without internet access on my computer, I don't think I'll be posting pics soon. Hell I just finished a few major projects and I am not able to make a post about any of them!!! Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 1, 2007 Share Posted May 1, 2007 Well when I did it, I didn't have any ride quality whatsoever... since I set the rump roast end on the bumpstops:rolleyes: IIRC, I reclocked the trailing arms but in theory, if you reclock them a couple teeth, then the spring effect will be stock, just sitting lower then stock ride height Link to comment Share on other sites More sharing options...
Durania Posted May 1, 2007 Share Posted May 1, 2007 Hes not the only one with the rump roast end in the air problem, I have it on my brat as well: Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted May 5, 2007 Share Posted May 5, 2007 Durania717 said: Hes not the only one with the rump roast end in the air problem, I have it on my brat as well: Same with my Brat, stock. But my '80 wagon got 4" more lift cuz I clocked em to lift it. Gonna slam the Brat though. Link to comment Share on other sites More sharing options...
Phizinza Posted May 5, 2007 Share Posted May 5, 2007 Have you looked at bratmans thread? http://www.ultimatesubaru.org/forum/showthread.php?t=73119&highlight=torsion Might help you. Durania717 said: Hes not the only one with the rump roast end in the air problem, I have it on my brat as well: That's a problem? I quite like it up a little bit. When I put my EJ in though I had to adjust it down an inch because it was just ridiculus. The brat in that pictures looks awesome I reckon... I like it so the tray sides are level, I think it looks best then. Link to comment Share on other sites More sharing options...
Durania Posted May 5, 2007 Share Posted May 5, 2007 Phizinza said: The brat in that pictures looks awesome I reckon... Thanks Phiz. Link to comment Share on other sites More sharing options...
