AKIRA Posted April 28, 2007 Share Posted April 28, 2007 It is my stepmothers 99 forester automatic, ej25 shoc. after replacing the drivers side headgasget, we hook everything up except the radiator hoses, and connect the battery. when the battery is connected - no matter what key position (it doesn't even have to be in the ignition) the front turn signals, brake lights and instrument cluster lights (as in the light bulbs that backlight everything in the car, not the warning lights themselves) flash over and over. they flash at half the rate of a normal turn signal flash, they flash for one minute, then stop for ten seconds, then flash for another minute, and repeat. we have checked our electrical connections, and we are clueless as what this could be. Link to comment Share on other sites More sharing options...
nipper Posted April 28, 2007 Share Posted April 28, 2007 www.cars101.com Its a common thing that happens when you remove the battery. Have you tried cycling the key fob a few times. nipper Link to comment Share on other sites More sharing options...
AKIRA Posted April 28, 2007 Author Share Posted April 28, 2007 I will try that, but I have to wait until tomorrow, since the battery in her remote is dead. Thank you. Link to comment Share on other sites More sharing options...
3Pin Posted April 28, 2007 Share Posted April 28, 2007 I just had the same thing happen to me on my 98 Forester. Nothing works but this. Turn the key on but no start and find a little black button under the dash to the left of the wheel and press it with the key on. Your locks should cycle up and down 3 times. Turn the key off and you are done with the lights on and off 30 times and then off. Some Foresters have the button recessed in a circular switch. Mine was just a little black button attached to the wiring near the two green plugs which you DO SHOULD CONNECT!!!!!!!!!!!!!! Try that. Link to comment Share on other sites More sharing options...
OB99W Posted April 28, 2007 Share Posted April 28, 2007 [...]Mine was just a little black button attached to the wiring near the two green plugs which you DO SHOULD CONNECT!!!!!!!!!!!!!! I assume that was meant to say "SHOULD NOT CONNECT". The "green plugs" are for diagnostic purposes, and normally are left apart. Link to comment Share on other sites More sharing options...
3Pin Posted April 28, 2007 Share Posted April 28, 2007 Holly Fruedian slip! That is correct. Do not connect them. They caused my lights to start flashing. Good luck. Link to comment Share on other sites More sharing options...
AKIRA Posted April 29, 2007 Author Share Posted April 29, 2007 ok, I was able to get to cvs and buy a new battery for her remote, I did the lock/unlock, and it works fine now. thanks. Link to comment Share on other sites More sharing options...
