1997outback Posted May 1, 2007 Share Posted May 1, 2007 hi everyone i cant seem to locate the dip stick for my 2000 obw. i need to check the level, there is a delay when i shift into drive from park. thanks Quote Link to comment Share on other sites More sharing options...
shaggywerewolf Posted May 1, 2007 Share Posted May 1, 2007 hi everyone i cant seem to locate the dip stick for my 2000 obw. i need to check the level, there is a delay when i shift into drive from park. thanks Should be on the driver's side, just medial and deep to the washer fluid reservoir. It's kind of hidden down there, and you'll have to navigate some hoses. Quote Link to comment Share on other sites More sharing options...
Kilroy Posted May 1, 2007 Share Posted May 1, 2007 Once you do find and remove it, spray the top of it with a bright colored paint to make it easier to find in the future. Quote Link to comment Share on other sites More sharing options...
jamal Posted May 1, 2007 Share Posted May 1, 2007 Isn't it bright yellow? Mine is anyway. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted May 1, 2007 Share Posted May 1, 2007 There are a number of posts of people who developed slow to engage into drive on '99's and some '00's. But yes checking fluid level reguarly is good to do. The procedure is in your manual; basically check in park engine running on level surface after vehicle has shifted through all gears. Quote Link to comment Share on other sites More sharing options...
