misledxcracker Posted May 1, 2007 Share Posted May 1, 2007 Would it be possible to wire a light to the ECU (the original code-reading light) and maybe stick said wire and light in an empty slot at the idiot light area? Then you wouldnt have to STOP and look under the dash for codes... just look right there, and there it is Think its doable with a little soldering iron, a small bulb, and some thin-gauge wire? Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted May 1, 2007 Share Posted May 1, 2007 Would it be possible to wire a light to the ECU (the original code-reading light) and maybe stick said wire and light in an empty slot at the idiot light area? Then you wouldnt have to STOP and look under the dash for codes... just look right there, and there it is Think its doable with a little soldering iron, a small bulb, and some thin-gauge wire? theoretically, yes. i think all it would involve is opening the ECU and soldering in a length of wire between the ECU and light. i'd suggest trying it on a junkyard box first though, or have a back up ECU available. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 1, 2007 Share Posted May 1, 2007 A fiber optic cable would work, since they tend to be powered by LED's anyway. nipper Quote Link to comment Share on other sites More sharing options...
chef_tim Posted May 1, 2007 Share Posted May 1, 2007 I'm not sure of the year(s) but I belive some mid-eighties Subbies had the Check Engine light that doubled as the comp trouble code light. See, they pay those engineers big bucks for a reason . Tim Quote Link to comment Share on other sites More sharing options...
robm Posted May 1, 2007 Share Posted May 1, 2007 There are big "check engine" connectors hanging off the ECU, that no one seems to use. Does the CEL come out to one of the pins one one of these connectors? It would make the soldering easier, and safer for the ECU. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 1, 2007 Share Posted May 1, 2007 The CEL does go through one of those connectors. But the o2 light that you read the codes on inside the ECU is not the CEL. If you want to set up a "remote" code light, it would need to be soldered. Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted May 1, 2007 Share Posted May 1, 2007 If you tapped right into the O2 monitor lamp, it would work, but you'd get a blinky light while driving. The O2 monitor is named just that for a reason, it comes on when the O2 sensor sees a rich condition, and turns off on a lean condition. It'd get kinda annoying with all the crosshatching it does at cruise. Quote Link to comment Share on other sites More sharing options...
