Subaru_dude Posted May 2, 2007 Share Posted May 2, 2007 the clutch kit i bought from napa has some instructions with it and they say to put the mark on the pressure plate 180 degrees from the "0" on the flywheel. for the life of me, i don't see either one. I guess it would be for balance. has anybody ever worried about that when installing a clutch? this is an '89 ea82 with a freshly resurfaced flywheel. thanks all. Link to comment Share on other sites More sharing options...
Gloyale Posted May 2, 2007 Share Posted May 2, 2007 Subaru_dude said: the clutch kit i bought from napa has some instructions with it and they say to put the mark on the pressure plate 180 degrees from the "0" on the flywheel. for the life of me, i don't see either one. I guess it would be for balance. has anybody ever worried about that when installing a clutch? this is an '89 ea82 with a freshly resurfaced flywheel. thanks all. 0 on the flywheel will be on the outer edge. I've never noticed any marks on the pressure plate though. I don't think you will have any problems if you don't find the mystery mark. Just tighten down the plate evenly and make sure you've got it properly on the dowel pins before tightening. Link to comment Share on other sites More sharing options...
Snowman Posted May 2, 2007 Share Posted May 2, 2007 I've never heard of that. The flywheel should be balanced and the pressure plate should be balanced, so I really can't see why it would matter. Link to comment Share on other sites More sharing options...
joostvdw Posted May 2, 2007 Share Posted May 2, 2007 in the FSM it says to mount the PP with the markings more than 120 degrees rotated compared to the 0 mark on the flywheel I couldn't find either so I just put it on and never had a problem.. Link to comment Share on other sites More sharing options...
Subaru_dude Posted May 2, 2007 Author Share Posted May 2, 2007 alright, i won't worry about it then. i just remember hearing about somebody on here who just did a clutch job, and had a constant vibration that was affected by engine speed and couldn't figure it out... and it turned out that it was his pressure plate mark not being at least 120 deg. off, but i think newer pressure plates come out of the factory balanced. Link to comment Share on other sites More sharing options...
azsubaru Posted May 2, 2007 Share Posted May 2, 2007 I think you're right not to worry about it, but I've got my engine out right now and one of the things I'm doing is putting in new clutch parts, so I can see exactly what you're talking about. The 0 on the flywheel - at least on mine - is on the side, very close to the teeth, and about opposite the three timing lines. The one on the pressure plate is in a very similary spot, stamped into the metal. Link to comment Share on other sites More sharing options...
msteel Posted May 3, 2007 Share Posted May 3, 2007 I'm pretty sure I've seen the -0- mark in my flywheel, through the timing hole in the bellhousing. I've not had to do a clutch, so I don't know about any marks on the pressure plate. Link to comment Share on other sites More sharing options...
