RedRum Posted May 3, 2007 Share Posted May 3, 2007 My brother failed his inspection today and the guy told him he has an exhaust leak and a bad catalytic converter. It is a 95 legacy L wagon with 240K miles. Is there a way to clean things out so he would pass emissions? Is there anywhere to find cheap cat converters for that car? Link to comment Share on other sites More sharing options...
Leg93 Posted May 3, 2007 Share Posted May 3, 2007 I always used ''Guaranteed to Pass'' from Autozone or Checker. It's about $7 a bottle, but if you don't pass, you just send in a copy of the failed report and your receipt and they refund your money. You run it for a tank, fill up again, then test. It worked for me everytime, never needed a refund. If all you are looking for is to pass emissions this might be an option. Of course, taking care of the problems will result in longer life and better performance for your car, not to mention the whole global warming blah blah blah. I used it because even after replacing everything that might cause my failure problems, I still failed. I figured after dumping over $500 in to a 10 year old car just to get it to pass emissions, I was entitled to a little GTP. Good luck. Link to comment Share on other sites More sharing options...
porcupine73 Posted May 3, 2007 Share Posted May 3, 2007 You may have to patch/fix the exhaust leak to pass. Do they like sniff the exhaust while running or do a dyno test or something? Otherwise most states have a DMV web site listing exactly what is 'required' to be checked during inspection. If it's an exhaust sniff test, I've heard running several bottles of 'isoheet' or similar isopropyl may help. Also get the car good and warmed up before going for the test, and leave it running in the parking lot while waiting. Link to comment Share on other sites More sharing options...
nipper Posted May 4, 2007 Share Posted May 4, 2007 If you have an exhaust leak and a dead cat, nothing will help you pass. My feeling is at that mileage they are probably two in the same. Look at the exhaust system yourself. A leaking exhaust us dangerous, espeically if it fairly forward in ther car. Hit the cat with hour hand when the cat is cold. If it rattles, the cat is scrap. nipper Link to comment Share on other sites More sharing options...
michaelbteam Posted May 4, 2007 Share Posted May 4, 2007 I have heard that runnning synthetic oil in an older engine will eliminate some of the emissions problem. Any agreement? Link to comment Share on other sites More sharing options...
nipper Posted May 4, 2007 Share Posted May 4, 2007 Somestimes an oil change in general will help, but thats only if its boarderline. nipper Link to comment Share on other sites More sharing options...
RedRum Posted May 8, 2007 Author Share Posted May 8, 2007 thanks guys...I am going to get under and take a look. If he wants one more year out of the car I might try a shortcut fix. Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 9, 2007 Share Posted May 9, 2007 Fix the hole in the exhaust. It's probably in the piping coming off the cat, so the cat itself may be fine, the metal is just rusted out. Use a Mig welder to tack it back toghether Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted May 9, 2007 Share Posted May 9, 2007 My brother failed his inspection today and the guy told him he has an exhaust leak and a bad catalytic converter. It is a 95 legacy L wagon with 240K miles. Is there a way to clean things out so he would pass emissions? Is there anywhere to find cheap cat converters for that car? if you have a bad Cat the chances are that it's shredded inside and you need a new one. no amount of chemicals in a bottle will fix that. Link to comment Share on other sites More sharing options...
