Where's the ECU for the air suspension?
Just for information since I removed the driver seat today for some heavy cleaning. All I have read so far stated that this ECU is beneath/under the driver seat. But there is nothing... :confused: Or is it under the carpet? And how big is it? I have a 1989 Leone/Loyale Station with air suspension. Thanks :)
The power window unit is under the pasenger seat, under carpet. So you may well be that the Air Susp. unit is uunder the carpet.
ha ha....2 packs of smokes, that's awesome.
it's huge, you can't miss it, you just need to lift the carpet up. or cut it. remove the drivers bottom plastic molding/trim holding the carpet and you should have access to it.
