subaruguru Posted May 7, 2007 Share Posted May 7, 2007 ok so i got this new car it is an 86 soob 4x4 push button 5speed turbo ea82 it runs but really sputtery and such then when the key is in the on position ther is a clicking sound the lights dim and i hear lish faint noise form the passenger side and the computer box under the sterring colum has a light that blinks when this is going on any help pleas thanks Rob:burnout: Link to comment Share on other sites More sharing options...
daeron Posted May 7, 2007 Share Posted May 7, 2007 unplug the green connectors under the hood, at the back of the engine bay, driver side. they are for testing purposes only. If there is a white one-wire connector plugged in that comes out of the harness in the same spot, unplug that as well. Link to comment Share on other sites More sharing options...
nvexplorer Posted May 7, 2007 Share Posted May 7, 2007 It sounds like your diagnostic wires are connected. I'm not sure where they would be on your car, but my 93 loyale has them located under the hood against the drivers side firewall. There's two white connectors and two green ones. The green ones put it in D check mode, which disables the computer timing advance and starts the solenoids clicking on and off. The white connectors pull any codes from your computer, which can be read by the blinking light on the computer. There is a write up on that in the USRM. Connecting both sets at the same time is supposed to clear the codes from the ecu. If the green connectors are connected, disconnect them. This should hopefully fix the sputtering too. Link to comment Share on other sites More sharing options...
Gloyale Posted May 7, 2007 Share Posted May 7, 2007 unplug the green connectors under the hood, at the back of the engine bay, driver side. they are for testing purposes only. If there is a white one-wire connector plugged in that comes out of the harness in the same spot, unplug that as well. On MPFI cars like your 86 gl-10 they are under the ECU. Sound like they are connected, they should not be normally. They are only for testing and reading codes. The 2 black connectors down there are the READ connectors, they should be unplugged for normal driving as well. Sputtery? check all the plugs and make sure the tube from Maf to Turbo, and all the Vac and PCV hoses are connected and in good condition. Link to comment Share on other sites More sharing options...
subaruguru Posted May 7, 2007 Author Share Posted May 7, 2007 ok i got it all fixed but i was wondering the dash has a little car on it that says hight controlle can i contol the hight or dose the car do it itself ?? thanks Rob Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 8, 2007 Share Posted May 8, 2007 there's a button to the left of the instrument cluster where the rear defrost and cruise is. It'll be at the bottom of that column. Should say "HEIGHT" on it. Push it in, car raises like an inch and a half. Push it again to disable it. Link to comment Share on other sites More sharing options...
subaruguru Posted May 8, 2007 Author Share Posted May 8, 2007 hey i looked and ther isnt a button ther is a cruse controlle one but not a hight button so why dose it have the car on the cluster ?? Rob Link to comment Share on other sites More sharing options...
Gloyale Posted May 8, 2007 Share Posted May 8, 2007 hey i looked and ther isnt a button ther is a cruse controlle one but not a hight button so why dose it have the car on the cluster ?? Rob Either someone swapped dashes, or it had Air suspension and somneone removed it and took the button too. Open the hood ook at the tops of the struts. Are there black platic covers that have writing like *air suspension* or *Height control* I forget what they say but basically look and see if it look like it has Air suspension. If not I'll bet someone swapped the dash. Which means it may have more (or less) miles than shown. Link to comment Share on other sites More sharing options...
