Dickensheets Posted May 7, 2007 Share Posted May 7, 2007 My wife wants the LATCH stsyem bad for our two couch monkeys. My options are: 1) newer car 2) roll my own system If someone could post a photo of their's I would appreciate it. I beleieve they are standard equipment on all 2000 and newer cars. Should be under or in the vicinity of the seat bottom near the seatbelts. Thanks, Ryan 97OBW Limited Link to comment Share on other sites More sharing options...
porcupine73 Posted May 7, 2007 Share Posted May 7, 2007 Here is what I think you are talking about from my '00obw. It has it for the center rear seat. Link to comment Share on other sites More sharing options...
NV Zeno Posted May 8, 2007 Share Posted May 8, 2007 Actually, the LATCH points are simply steel "loops" or D rings bolted to the floor. To find them, they're usually painted black and are found between the bottom of the seatback and the bottom cushion. Sort of next to where the seatbelts pictured above are anchored. Sorry no pix (I've got an earlier model) but I work with new cars every day, and that's where most of the LATCH anchors are...some are also on the floor of the "wayback" part of station wagons, just behind the back seat. Link to comment Share on other sites More sharing options...
porcupine73 Posted May 8, 2007 Share Posted May 8, 2007 Hm....ok is that what this thing is? Link to comment Share on other sites More sharing options...
NV Zeno Posted May 8, 2007 Share Posted May 8, 2007 Nope. It's usually (I'm trying to remember what they look like in Subarus) just a steel loop about 1 1/2 inches bolted to the floor, painted gloss black..nothing attached to it. IIRC on Subarus, there's a plastic cover about 2 inches square, same color as the upholstery, that covers the hole that the anchor resides in. Embossed on that cover is a pic of a boat anchor on a chain. Easily flipped up or removed, revealing the LATCH anchor. Link to comment Share on other sites More sharing options...
Dickensheets Posted May 8, 2007 Author Share Posted May 8, 2007 Nope. It's usually (I'm trying to remember what they look like in Subarus) just a steel loop about 1 1/2 inches bolted to the floor, painted gloss black..nothing attached to it. IIRC on Subarus, there's a plastic cover about 2 inches square, same color as the upholstery, that covers the hole that the anchor resides in. Embossed on that cover is a pic of a boat anchor on a chain. Easily flipped up or removed, revealing the LATCH anchor. Thanks for the effort porcupine73. I will look for these on my car and if they are not there I will consider a nuts and bolts solution. rd Link to comment Share on other sites More sharing options...
1997outback Posted May 8, 2007 Share Posted May 8, 2007 so does an 2000 obw limited have latch system, or anchors? my 1st child is due anyday now. pic would be awesome. Link to comment Share on other sites More sharing options...
Dickensheets Posted May 8, 2007 Author Share Posted May 8, 2007 so does an 2000 obw limited have latch system, or anchors? my 1st child is due anyday now. pic would be awesome. It should. Congrats by the way. rd Link to comment Share on other sites More sharing options...
Strakes Posted May 8, 2007 Share Posted May 8, 2007 http://www.pbase.com/image/2493846 http://www.carseat.org/Legal/622_Latch.htm The latch looks like this (metal "D" ring attached to a hard point on the car between the top and bottom seat cushions). When I get home tonight, I'll post a pic from my 2002 that has them. Link to comment Share on other sites More sharing options...
1997outback Posted May 9, 2007 Share Posted May 9, 2007 i check and i did not notice any "D" ring under the seat when i fliped it up. the obw does have top strap anchors, but that wouldnt help. we went to the chp and they help us fit it better. Link to comment Share on other sites More sharing options...
Strakes Posted May 9, 2007 Share Posted May 9, 2007 Latch pics attached. You need of these 2 "Latches" per car seat. I saw a universal retrofit at Baby's R Us a few months ago. However, I bet you can just go to the hardware store and get the appropriate d hook and mounting bolts as well. Link to comment Share on other sites More sharing options...
