lhrocker Posted May 8, 2007 Share Posted May 8, 2007 How do you get the radio panel off a Legacy that doesn't have an ashtray? On my 95, when I removed the ashtray, there were screws that needed to be removed. On my 97, which has a plastic holder in place of the ashtray, how do I get it out? I assume that the screws that need to be removed are still there, but I can't seem to remove this plastic piece without breaking it. Any suggestions? Thanx, Pete Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted May 8, 2007 Share Posted May 8, 2007 bump Quote Link to comment Share on other sites More sharing options...
Kilroy Posted May 8, 2007 Share Posted May 8, 2007 I replaced my stock radio with a JVC AVX33 yesterday. If you have a cup holder, slide it completely out and there should be screws behind it. I'm not sure if this is the case with the '97, but give it a shot. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 8, 2007 Share Posted May 8, 2007 gently pop outt the plate. I have a multiple outlet there that just snaps in, that should be the same. Then there are two screws under that plate pointing up that have to come out. nipper Quote Link to comment Share on other sites More sharing options...
lhrocker Posted May 9, 2007 Author Share Posted May 9, 2007 The holder does come out with just a tug (albeit a hard one). Thanx again Nipper. The new radio is in a blasting!!! Quote Link to comment Share on other sites More sharing options...
