bglombowski Posted May 8, 2007 Share Posted May 8, 2007 Hello all, I suppose I could do hours of research, but maybe it's quicker to just ask. I recently bought my first soobie, an '86 brat with an EA-81. When starting it "cold", it seems to be missing on one cylinder and idles at about 1100rpm. It spits a little bit of oil and smoke out the tailpipe. Not huge amounts, more like a very light mist. After a few minutes of driving then stopping, it idles at 2000-2300rpm. After a few more minutes it seems to be running normal like one would expect with plenty of power (relatively). When it's warmed up good, there's no apparent smokey exhaust. But then, it idles down a little too low and stalls if I don't feather the pedal. I replaced the spark plugs and wires. Should I now replace the cap/rotor? I also just installed a missing preheater hose that goes between the exhaust and intake. No difference there. I don't know what kind of gas mileage I'm getting because I don't fill it up all the way because there's a minor leak near the top somewhere. I'll figure that out later. I'm guessing the mileage is about 28-30mpg. So does anybody know these engines so well that they can help me?:-\:-\ Link to comment Share on other sites More sharing options...
nipper Posted May 8, 2007 Share Posted May 8, 2007 You really should do a full tune up, which includes Plug Wires (which you already did). Cap Rotor Fuel Filter Pcv Air filter. Its been so long since i looked at one of these, i dont remember alot. You should do a compression test and see what condition the engine is in. The oil out the tail pipe doesnt sound too good, but can be as simple as tired valve stem seals. nipper Link to comment Share on other sites More sharing options...
Gloyale Posted May 8, 2007 Share Posted May 8, 2007 nipper said: You really should do a full tune up, which includesPlug Wires (which you already did). Cap Rotor Fuel Filter Pcv Air filter. Its been so long since i looked at one of these, i dont remember alot. You should do a compression test and see what condition the engine is in. The oil out the tail pipe doesnt sound too good, but can be as simple as tired valve stem seals. nipper I agree. A faulty PCV system will cuase oil to get sucked into the intake. And then the Wacky ASV(air suction Valve) introduces Air from the intake to the exhaust to eleiminate backfires. Could be part of the oil thing Link to comment Share on other sites More sharing options...
