TheMeatWagon Posted May 9, 2007 Share Posted May 9, 2007 I'm thinking about going and picking up a wagon tomorrow. It's an '86 that was used as a beer delivery car for years. It has 120k miles on the ea82 and ran strong before it was parked. It got a 4" lift and swampers put on, then driven 10 miles and parked. It's been sitting there for 10 months. Now it won't start because of a dead battery, but I'll take a battery down when I go. Do you think it will be driveable once I swap the batter? Should I risk the long drive to get it? I don't have access to a truck right now unfortunately, otherwise I'd tow it. What should I replace when I get it back? Link to comment Share on other sites More sharing options...
Manarius Posted May 9, 2007 Share Posted May 9, 2007 Why would you be worried? As long as there aren't like rats anywhere they aren't supposed to be, I think it'll fire right up after you get the gunk out of the carb. Might take a little ether, but it should go. My 1965 LeMans can sit for 10 months and fire right up whenever I want it to. Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 9, 2007 Share Posted May 9, 2007 Around my neck of the country, we'd be verry supicious of the brake lines after sitting for any longer than 6 months. But out there you guys don't have that rust thing, so it should probably be fine. Link to comment Share on other sites More sharing options...
TheMeatWagon Posted May 9, 2007 Author Share Posted May 9, 2007 Yeah no salt around here. I think I'll be fine, just wondering if there was anything I should look out for. Thanks Hey are there any problems with driving a lifted soob long distances? The guy said it might be a little hard on the axles but I didn't think it'd be too bad. Link to comment Share on other sites More sharing options...
SakoTGrimes Posted May 9, 2007 Share Posted May 9, 2007 My Brat sat for 5 YEARS before I got it. Ran like crap for a while with old gas and old plugs, blowing circular smoke rings and whatnot, but it cleared up just fine after an oil change, new plugs, air cleaner, fresh gas and a little RPM Flexing Link to comment Share on other sites More sharing options...
TheMeatWagon Posted May 9, 2007 Author Share Posted May 9, 2007 Do you think your Brat would've made a 5 hour drive in that condition? I assume the thing probably will start okay, but it's a long drive home. Link to comment Share on other sites More sharing options...
misledxcracker Posted May 9, 2007 Share Posted May 9, 2007 IMO, 10 months isnt that long. I think you'd be good to go. My car's never ran right, always had SOMETHING wrong with it, the cooling system is NOT up to par whatsoever, and I still drove it on a 6 hour drive, and also a 6 hour drive back about a week later, no problems at all, didnt have to stop throughout the whole round trip. I feel more confident in my old Subaru than in any other car I've owned for long trips, including three that were less than a few years old. Link to comment Share on other sites More sharing options...
subaruguru Posted May 9, 2007 Share Posted May 9, 2007 lol GO FOR IT the car i got sat in an old barn for 3 years befor i got it and i puta battery in it fired it up and drove it home put 5 galloins of premo gas and some fule injector cleaner and she is the fastest wagon ive ever owned (shes a turbo of course Link to comment Share on other sites More sharing options...
Durania Posted May 9, 2007 Share Posted May 9, 2007 My hatch sat for a few years and fired right up. Link to comment Share on other sites More sharing options...
P K Posted May 9, 2007 Share Posted May 9, 2007 That VW in Sleeper sat for 200 years - fired right up, LOL. Link to comment Share on other sites More sharing options...
SakoTGrimes Posted May 9, 2007 Share Posted May 9, 2007 Do you think your Brat would've made a 5 hour drive in that condition? I assume the thing probably will start okay, but it's a long drive home. It made a 30 hour drive on the same oil.:cool: Link to comment Share on other sites More sharing options...
Milemaker13 Posted May 9, 2007 Share Posted May 9, 2007 My loyale sat for like 4 yrs before I got it. Ran fine. I see no problem driving that car home. Maybe take it easy, at least at first. Also, I'd change the oil before hitting the road, definatly. Just bring the stuff w you, or I guess stop at Jiffy Lube(although in my opinion, thats more of a risk than just driving it home-JIFFY LUBE SUCKS!!!) Make sure you check their work, especially the oil filter. How much did you give for the car? Just curious! Link to comment Share on other sites More sharing options...
RONAN Posted May 9, 2007 Share Posted May 9, 2007 Biggest concern would be bad gas. I would try to syphon out and replace as much as possible. I would also change the oil after driving it a short distance to remove any condensation build-up. Just one mans opinion.:cool: Link to comment Share on other sites More sharing options...
daeron Posted May 9, 2007 Share Posted May 9, 2007 I would recommend getting a quart of marvel mystery oil. Remove the feed line to the fuel pump and drain out any fuel in there, pour the MMO in, drain that out, and pour a gallon or two of good fresh fuel in there. Get to a gas station and add some lucas fuel injector cleaner, or seafoam, or something of that nature to 8 gallons of fuel or so, (or a full tank, i guess, if youre driving a good distance) and you should be fine. Changing the oil would probably be a wise thing as well; if you do that, you might want to add some MMO or seafoam to the oil before you start out, just to give yourself some added flushing. BUT some fuel precautions, and a simple oil change, are probably more than sufficient. The more you do, the greater your peace of mind; but something is ALOT more than nothing, and going to great lengths eventually does encounter a point of diminishing return.. it WAS only 10 months, after all... Play it safe and keep an eye on the cooling system; make sure the radiator is full of coolant and check to make sure the fan comes on as it should. If not, a simple jumper wire installed in place of the temp switch in the passenger side tank of the radiator will make it run whenever the key is on, providing the fan itself actually works. Link to comment Share on other sites More sharing options...
heartless Posted May 9, 2007 Share Posted May 9, 2007 bought my car after it sat for a year and a half - new battery and some fresh fuel and it fired right up. got it home and did some basic maintenance (oil change, plugs wires, etc and some not so basic maintenace - clutch, axles) and have been driving it for nearly six years now. Link to comment Share on other sites More sharing options...
Sweet82 Posted May 9, 2007 Share Posted May 9, 2007 Buy it, Drive it! Check the oil and fluids before you head out. Give it a complete tuneup when you get time... Link to comment Share on other sites More sharing options...
TheMeatWagon Posted May 10, 2007 Author Share Posted May 10, 2007 Well I went ahead and drove down today with a buddy of mine. Got there and threw the new battery in it an no start . No power anywhere. So I check everything over and sure enough a fusible link is in 2. Twisted it together and fired right up . Had to rev it for a few minutes to get all the gunk out but after that it purred. Paid the guy and drove back into town and got an oil change. Looked around some more and the cap and wires were sooooo bad I don't even know how it ran. Replaced those, put a gallon of water in the rad, got a new air filter, and it sounded great. Driving was seriously messed up though. Something was wrong. Looks like the back right wheel bearing is toast. The wheel has like an inch of play. By the time I got home it was nearly totally seized, it was like driving with the parking break. But I made it home!!! Tomorrow I have a few more things to replace and it should be great. It has a brand brand new 4" AA lift, brand new AA 15" wheels, and brand new 29" swampers. Pics will follow . Link to comment Share on other sites More sharing options...
Sweet82 Posted May 10, 2007 Share Posted May 10, 2007 Impatiently waiting for pics.... Link to comment Share on other sites More sharing options...
TheMeatWagon Posted May 13, 2007 Author Share Posted May 13, 2007 Sorry I don't have pics yet. The rear end has been jacked up and the rear right suspension has been totally taken off since I got it. Waiting to drop it back down and power wash some of the green algae looking crap off the paint, then I'll snap a few pictures . Link to comment Share on other sites More sharing options...
