ratios...
I would like to know if reduction ratios in D/R gearbox (88 wagon) depends on what kind of gearbox it is (normal -1.59; ft4wd - 1.19) or if it is turboed (turbo - 1.19; N/A - 1.59).
Mine is turbo AND ft4wd so I have awsome 1.19 but I want to change it so I need to know what should I look for to get 1.59....
Piotr
I believe Donald missed a word. He says'the 5spd never came with the turbo" What he should have said is it never came with a dual range 5 speed, except in the RX which was really a 10 speed as it can be shifted high to low range at any speed. But the low is not as low as it is in a dual range, only about a half gear, this designed more for rallying than for off road
yeah, i was referring to the dual range.
the exception is the dual range RX trans, 3.7 full-time, but that would be referred to as the RX trans.
then there are 5spd pushbutton, single range, both turbo and non turbo
so 5spd dual range refers to all the 3.9 that did not come with a turbo
