buzzlenox Posted May 13, 2007 Share Posted May 13, 2007 I Have An 89 Gl With A 1.8 Fi I Have No Spark, I Changed The Ignition Coil And Distributor, I Have Power To Both Sides Of My Coil But Still No Spark. I Have No Idea What Else It Could Be, All Fuses And Links Work, Timing Is Correct, I Have Two Mechanics And Myself Stumped, Please Help!!!!! Link to comment Share on other sites More sharing options...
jonas Posted May 13, 2007 Share Posted May 13, 2007 bad wire from coil to disty? Link to comment Share on other sites More sharing options...
Sister7 Posted May 14, 2007 Share Posted May 14, 2007 I would reccomend checking the coil bracket. The bracket has a transistor on the bottom of it (called "ignition impulse amplifier") that can go bad. Also, the bracket itself serves as a ground, so make sure it's tight and clean. Otherwise, we're probably talking ECU issues. Hope this helps! Link to comment Share on other sites More sharing options...
heartless Posted May 14, 2007 Share Posted May 14, 2007 yup, sounds like the ignition amplifier - had one go bad on my car a couple of years ago (also an 89 SPFI) - took a while to figure it out. didnt kill the spark completely, but it was very weak. swapped out the bracket - made sure it was grounded good - had to tap out the mounting hole and put in a slightly larger bolt, old one was loose - and it fired up no problem. a special thanks goes to Skip for all the help he gave me while trying to diagnose the problem. Link to comment Share on other sites More sharing options...
Gloyale Posted May 14, 2007 Share Posted May 14, 2007 Have you taken the disty cap off and verified that the rotor is connected well and turns when the engine is cranked? If it doesn't turn you've got a broken belt. Won't spark becasue the disty won't turn. Link to comment Share on other sites More sharing options...
