srs_49 Posted May 19, 2007 Share Posted May 19, 2007 If the empty light is working properly, maybe 60 miles, tops. This in a 2002 OBW, H6. Link to comment Share on other sites More sharing options...
forester2002s Posted May 19, 2007 Share Posted May 19, 2007 I got 40-km (25 miles) out of my 2002 Forester MT5, before the engine started misfiring, and I then refuelled from a portable gas-can. Link to comment Share on other sites More sharing options...
nipper Posted May 19, 2007 Share Posted May 19, 2007 forester2002s said: I got 40-km (25 miles) out of my 2002 Forester MT5, before the engine started misfiring, and I then refuelled from a portable gas-can. someone always has to be a trouble maker :-p nipper Link to comment Share on other sites More sharing options...
mrtoyou7747 Posted May 19, 2007 Share Posted May 19, 2007 My 98 OBW takes 13.7 gal to full once the light comes on "full". Been like that for 134K miles and many fillups. You can ge the light to come a bit earlier if your on a hill or a tight turn like on an exit ramp but it will shut off once your stabilized. Once the light comes on full I look for a gas station. Link to comment Share on other sites More sharing options...
Tanispyre Posted May 23, 2007 Share Posted May 23, 2007 firstwagon said: Where do you get Techron? I can't find anything called that (or claiming the ingrediant) at the local auto parts stores. Techron is the cleaning formula used in Chevron fuels, it is often also sold as a fuel additive. Look for a fuel system cleaner made by Chevron, that should be the techron additive. Link to comment Share on other sites More sharing options...
sparkster58 Posted May 23, 2007 Share Posted May 23, 2007 i think you have 2 gal in reserve....go figure the MPG.....spark:cool: Link to comment Share on other sites More sharing options...
2X2KOB Posted June 14, 2007 Share Posted June 14, 2007 I just checked this again: Light came on at 380.7 miles Fill up at 383.2 miles Fill amount = 14.2 gallons MPG = 26.99 miles per gallon Tank capacity = 16.9 gallons Reserve fuel after light comes on = 2.7 gallons Distance after light comes on = 72.86 miles Theroretical max distance per tank of gas = 456.13 miles This is a 2000 OBW. Link to comment Share on other sites More sharing options...
rverdoold Posted June 14, 2007 Share Posted June 14, 2007 I got >50km, have to find out first time it went on last i drove 470km ok now some math (sorry guys metric ). tank capacity : 60 l (15.85 USG) tanked gas after ligth on : 46 l (12.15 USG) distance : 470 km (292 Mi) milage : 10.2 km/l (24.03 Mi/G) is this bad??!!?? (2.0l 2wd 4eat '91 legacy wagon) So with the 14 litres left is should be able to do at leas 140 more km but never went further than 480 km on a tank. But now comes the strange things. The distance given by the odometer differs from tire size ('91 legacy still with cable) and seems quite incorrect. Will try this with GPS once and see the difference and get the real Mi/G (since i trust the pump meter where i get the gasoline). Then there is something else weird. When the light comes on at the first moment and i take some turns (to the left) it goes off. Also when the tank is getting empty and i take left turns it becomes slightly fuller!? If i go to the right it becomes emptier again, i can even get it below the E line on the dail without having the ligth on (ensuring us the light and meter are really two separate sensors). Think will get a 5 l tank in the car and will bravely see if i can make at least 550 km. btw does anything bad happen to the automatic gearbox if the engine stalls or does it jumps into neutral??? Link to comment Share on other sites More sharing options...
nipper Posted June 15, 2007 Share Posted June 15, 2007 rverdoold said: I got >50km, have to find out first time it went on last i drove 470km ok now some math (sorry guys metric ). tank capacity : 60 l (15.85 USG) tanked gas after ligth on : 46 l (12.15 USG) distance : 470 km (292 Mi) milage : 10.2 km/l (24.03 Mi/G) is this bad??!!?? (2.0l 2wd 4eat '91 legacy wagon) So with the 14 litres left is should be able to do at leas 140 more km but never went further than 480 km on a tank. But now comes the strange things. The distance given by the odometer differs from tire size ('91 legacy still with cable) and seems quite incorrect. Will try this with GPS once and see the difference and get the real Mi/G (since i trust the pump meter where i get the gasoline). Then there is something else weird. When the light comes on at the first moment and i take some turns (to the left) it goes off. Also when the tank is getting empty and i take left turns it becomes slightly fuller!? If i go to the right it becomes emptier again, i can even get it below the E line on the dail without having the ligth on (ensuring us the light and meter are really two separate sensors). Think will get a 5 l tank in the car and will bravely see if i can make at least 550 km. btw does anything bad happen to the automatic gearbox if the engine stalls or does it jumps into neutral??? Engine stalls, the car just rolls. The tranny pump looses pressure so it is like being in neutral. 24 mpg is not bad. It takes at least 3 tanks of gas to determine baseline MPG. i get 20/24 in my 2.5L OBW auto. i can see 29mpg if i stick to 60, but thats no fun. Also do 60 here and you back up traffic. nipper nipper Link to comment Share on other sites More sharing options...
Virrdog Posted June 15, 2007 Share Posted June 15, 2007 I hope everyone remembers you can't squeeze every last ounce of gas out of the tank. Anything less than a gallon left and the car is prone to hesitation and bucking from the gas sloshing away from the fuel pickup... in the BC/BF chassis anyways. You can only make it as far as the pickup can keep sucking up gas. Link to comment Share on other sites More sharing options...
Gnuman Posted June 15, 2007 Share Posted June 15, 2007 OK, I can't stand it anymore. I have to chime in. The car is a 92 Legacy 2.2L manual, 230K miles on it. The "feed me" light (c'mon, that is what it really means. . .) comes on intermittantly just below E, then I have about 40 miles range before the car goes bingo (out of fuel). The one time I let it go that far, the station was across the street, ande I got 15.3 Gal. into it. That last .5 gal was wasted, as the pickup could not get at it. Letting the fuel get this low is hard on the pump and on the engine, so I do not do so often. Emily (my car) likes Arco gas (BP), and I get between 20 and 30MPG depending on how I'm driving. All told I'm averaging about 25MPG on a 15 year old car with over 200K on the ticker. At that I'm also getting really good emmissions readings. I use about a quart and a half of oil in my 5K change interval (synthetic, but I do not trust the filter past 5K). Recently the feed me light has started to lie to me, going on when the guage is above E. I tell it to fsck off and after a bit it goes off, returning at a more reasonable time. Hey Nipper, got any thoughts on that one? I am considering pulling the fuel guage sender and cleaning it up sometime soon as well. Does anyone have a recomendation on a cleaner? Link to comment Share on other sites More sharing options...
nipper Posted June 15, 2007 Share Posted June 15, 2007 The feed me light can come on and off with the angle of the car. Its when it stays on that you need to pay attention to it. Mine flickers on and off about E (which is normal for any light) as the fule sloshes around, and as the jet pump (in AWD subarus) moves fuel around. It could be you may be due for a fuel filter, and thats affecting the jet pump effeciency. nipper Link to comment Share on other sites More sharing options...
hohieu Posted June 15, 2007 Share Posted June 15, 2007 nipper said: What he said. The light is a seperate mechanisim then the gauge, and is 100% repeatable and reliable (as long as the light doesnt burn out). nipper I ran out of gas in the middle of nowhere in Arkansas because, as I just learned, the fuel light burned out. How difficult is it to pull the instrument cluster and replace the light? Link to comment Share on other sites More sharing options...
nipper Posted June 15, 2007 Share Posted June 15, 2007 hohieu said: I ran out of gas in the middle of nowhere in Arkansas because, as I just learned, the fuel light burned out. How difficult is it to pull the instrument cluster and replace the light? The cluster comes out in about 3 minutes, its really simple.. nipper Link to comment Share on other sites More sharing options...
rverdoold Posted June 15, 2007 Share Posted June 15, 2007 nipper said: The cluster comes out in about 3 minutes, its really simple.. nipper Wished it was the same for the '91 legacy still have burned AT OIL lamp i think Link to comment Share on other sites More sharing options...
Virrdog Posted June 15, 2007 Share Posted June 15, 2007 rverdoold said: Wished it was the same for the '91 legacy still have burned AT OIL lamp i think Takes 5 minutes in your Legacy also. I've had mine out umpteen times. Link to comment Share on other sites More sharing options...
hohieu Posted June 15, 2007 Share Posted June 15, 2007 nipper said: The cluster comes out in about 3 minutes, its really simple.. nipper Thanks. It was very simple (Bulb #158). To replace it I didn't need to remove the culster completely as the low fuel light bulb is very accessible on the the bottom corner. As you pull out the plastic visor, there are just two screws on top and a couple of hook pawls the bottom corners -- just pull outward and the bottom pops out. I'm taking care of annoying little things, and will post a question about some other bulbs in a separate thread. Link to comment Share on other sites More sharing options...
hohieu Posted June 25, 2007 Share Posted June 25, 2007 Replaced the bulb and the light still doesn't work. I just took the fuel gauge needle down several times on a recent road trip, and still nothing. I refilled with close to 15 gallons several times. Can it be that the sensor has failed? Are there electrical connections I should check? I know it's a minor issue but an annoying one nonetheless. Link to comment Share on other sites More sharing options...
