Nug Posted May 17, 2007 Share Posted May 17, 2007 Fuse good, resistors good (one filament was burned out, soldered in one from a legacy). No power at any of the terminals of the blower motor switch or at the resistors. Where is the dang blower motor? I really don't want to pull the dash just to put a meter on the motor terminals. What feeds this circuit, and from where? I have 6 days to have working A/C for the BABE rally. *EDIT* 1982 GL Wagon *Edit again* I actually did a search. Tomorrow i look for blower motor relay. Link to comment Share on other sites More sharing options...
Cougar Posted May 17, 2007 Share Posted May 17, 2007 I agree that the relay is the most likely cause of the problem. My info says to look for it on a bracket, on the fuse panel. Link to comment Share on other sites More sharing options...
Gloyale Posted May 17, 2007 Share Posted May 17, 2007 Power goes from the relay straight to the blower motor. The switch and resistor control the ground side of the circuit so there would be no voltage measured at them. Wish I knew excactly were the relay is on an ea81, but I am guessing that to be the culprit. Link to comment Share on other sites More sharing options...
Nug Posted May 18, 2007 Author Share Posted May 18, 2007 Didn't get to it tonight. I was watching Joan of Arcadia. Link to comment Share on other sites More sharing options...
Nug Posted May 20, 2007 Author Share Posted May 20, 2007 It's the relay. Hit it with a screw driver, fan comes on. I ordered another, around $10. Now the kicker is that I turned on the a/c, and it works. Like it's nearly fully charged, and puts out nice cold air. I thought the compressor was locked up, but I must have mixed it up in my head with my vw dasher. I was going to swap the compressor, glad I didn't put a wrench on it! Link to comment Share on other sites More sharing options...
Cougar Posted May 20, 2007 Share Posted May 20, 2007 Good deal. Another case solved. Link to comment Share on other sites More sharing options...
