tidd1340 Posted May 17, 2007 Share Posted May 17, 2007 Mine is shot. I went with autopartsgiant. c om..said they had it..that was 4/22/07..i just filed a chargeback on my c/c as i have no part or refund,or any answers on where it is..anyone have a source for one of these? Or have a used one? The local stores want 99.00..hoped i could get one cheaper. Link to comment Share on other sites More sharing options...
rllywgn Posted May 17, 2007 Share Posted May 17, 2007 try the junkyards if available.. most of them have two temp sensors.. which one do you need? t-stat housing or block? Link to comment Share on other sites More sharing options...
tidd1340 Posted May 17, 2007 Author Share Posted May 17, 2007 t-stat one..2 wires w/green plug. Older subies in NY are hard to find in the yards..they just rust away.... Link to comment Share on other sites More sharing options...
daeron Posted May 17, 2007 Share Posted May 17, 2007 you sure its not just a wiring problem? the wires, or the terminals, go bad far more often than the sensors themselves. Rust is the main culprit of "bad," that is why I ask. Link to comment Share on other sites More sharing options...
SmashedGlass Posted May 17, 2007 Share Posted May 17, 2007 tidd1340 said: Mine is shot. I went with autopartsgiant. c om..said they had it..that was 4/22/07..i just filed a chargeback on my c/c as i have no part or refund,or any answers on where it is..anyone have a source for one of these? Or have a used one? The local stores want 99.00..hoped i could get one cheaper. wtf?? i think i paid about $15 for my sensor @ Checkers.....weird, man. Link to comment Share on other sites More sharing options...
Gloyale Posted May 17, 2007 Share Posted May 17, 2007 SmashedGlass said: wtf?? i think i paid about $15 for my sensor @ Checkers.....weird, man. MPFI uses a much more common style of sensor, connector plugs directly to it and there are no pigtails. The SPFI one has those wires and a connector. I believe you COULD use the MPFI one if you change the connector because they output in the same range. I am not sure if they have the same threads however. Link to comment Share on other sites More sharing options...
SubaRube Posted May 17, 2007 Share Posted May 17, 2007 I've been running an MPFI one in my SPFI for a year or so. No problems so far. For Comparison - http://www.partsamerica.com/ProductDetail.aspx?MfrCode=BOR&MfrPartNumber=WT5000&PartType=290&PTSet=A MPFI http://www.partsamerica.com/ProductDetail.aspx?MfrCode=GPS&MfrPartNumber=385186&PartType=290&PTSet=A SPFI ('88-'94) http://www.partsamerica.com/ProductDetail.aspx?MfrCode=NIE&MfrPartNumber=TS81381&PartType=756&PTSet=A SPFI ('86-'87 only -referred to as an "Air Charge Tempeperature Sensor") For some reason they charge almost double for the '88-'94 SPFI version than the '86-'87 version of essentially the same part, just with a diff. connector. Weird. Edit - I fixed all the links - should work now Link to comment Share on other sites More sharing options...
tidd1340 Posted May 17, 2007 Author Share Posted May 17, 2007 Subarube,can you post a p/n on the cheaper one? When i click the links i get just the expensive ones..thanks!! Link to comment Share on other sites More sharing options...
Gloyale Posted May 17, 2007 Share Posted May 17, 2007 COOL!!! sticky this or submit the change over process to the USRM. Link to comment Share on other sites More sharing options...
daeron Posted May 17, 2007 Share Posted May 17, 2007 its up to one of us to submit it to the USRM. I just submitted Bucky92's photo of the fuse panel cover. Link to comment Share on other sites More sharing options...
