pierman2 Posted May 18, 2007 Share Posted May 18, 2007 Does anyone have anything good to say about these engines? It seems as if the overwhelming majority would rather have a root canal than an ea-82 turbo. Anyone having a good time with their's? Link to comment Share on other sites More sharing options...
idosubaru Posted May 18, 2007 Share Posted May 18, 2007 yes there are people that like them and have good results. the problem is mostly age and limitatoins of the engine. with the age...nearly everything on any car needs attention, with the extra heat and abuse of a turbo they need it more. head gaskets, water pump, coolant hoses everywhere...throttle body, heater core inlet, heater core outlet, turbo return coolant line, turbo inlet coolant line and number smaller lines up front as well as the radiator lines, caps and the radiator itself...ideally all of that stuff and the turbo oil lines all need to be in great shape. turbo's overheat and blow headgaskets quick. not too mention turbo's need replacing and cause their own problems as well. keep everything in good shape and don't push the limits and they can be good cars. next is the limitations. start increasing power and you run into more problems. first..there's that long list of parts that are nearly 20 years old now. if you start looking into major and expensive mods for more power...it's easier just to upgrade to another engine that is newer, has more availability and can handle it. Link to comment Share on other sites More sharing options...
Gloyale Posted May 18, 2007 Share Posted May 18, 2007 I love mine but you have to be fanatical about the maintainence. Pretty much if you buy a new one tear it down and reseal it with all new belts, hoses, Check the pulleys, replace the thermostat. You never want to have one overheat. I personally have had pretty good luck with the 2 I've owned. You just gotta stay ahead on the maintance. Oh yeah and know the limits. Don't expect to build it into a *raging hot-rod* to quote a no longer with us member. Link to comment Share on other sites More sharing options...
Hodaka Rider Posted May 18, 2007 Share Posted May 18, 2007 Don't expect to build it into a *raging hot-rod* to quote a no longer with us member. Hee-Heee! That being said, if you throw a lot of preventive maintenance at it, you could turn it into a raging hot rod. If you have searched, you probably already know this though. Link to comment Share on other sites More sharing options...
subyrally Posted May 18, 2007 Share Posted May 18, 2007 i personally like the ea82t engines. i know them in and out and they are easy to work on. they are also pretty torquey. mine is pretty quick when it wants to be. dont get me wrong, they are very tempermental, they are like girls, very easily angered when neglected.my first engine popped cause of improper storage and rusted rings, the second one started to go when i made the mistake of letting the local meineke install a steering rack and some one knifed the top radiator hose to try to force me into more labor, then it finally went after another hose ripped in half on the high way and cracked the heads. the engine i am running now isnt top notch either, but it will work until i start working agian and get the new one built. basically think junk yard engine right now. Link to comment Share on other sites More sharing options...
Jub Nub Posted May 18, 2007 Share Posted May 18, 2007 yeah.. mines great! high comp turbo, lots o power. with a cold air intake they dont get hot. mine is a raging hot rod. so there. +1 on maintenance, though...:-\ Link to comment Share on other sites More sharing options...
subyrally Posted May 19, 2007 Share Posted May 19, 2007 obviously i love mine now i just need to fix a few little bits on the body and then get some money to build my not stock engine, Link to comment Share on other sites More sharing options...
Turbone Posted May 19, 2007 Share Posted May 19, 2007 To much money and effort for little return:-\ If you want a raging hot rod, put a EJ in and go from there:Flame: Link to comment Share on other sites More sharing options...
mikeshoup Posted May 19, 2007 Share Posted May 19, 2007 To much money and effort for little return:-\ +1 My High-Comp EA82 was anything but reliable. Perhaps if I had a low-comp one, I wouldn't be too disappointed. On the other hand, my EA81T, the pushrod predecessor to the EA82T has been nothing but reliable. Yet to leave me stranded. Just got a noisy lifter. Link to comment Share on other sites More sharing options...
tizzle Posted May 19, 2007 Share Posted May 19, 2007 Tear down the engine and replace seals & hoses and sensors, and get to know the car in the process. I like these engines even compared to my old ej25 and current Sti. They have a different feel to them. Link to comment Share on other sites More sharing options...
twobirds Posted May 20, 2007 Share Posted May 20, 2007 any of you guys that love them want to buy a project? 89 rx coupe white with all the spoilers, little rust, bhg, 2 sets of alloys one with snow tires.??? Link to comment Share on other sites More sharing options...
Gloyale Posted May 20, 2007 Share Posted May 20, 2007 I'd love to but I got no way to bring it to Wisconsin Link to comment Share on other sites More sharing options...
subyrally Posted May 20, 2007 Share Posted May 20, 2007 id love to, but my mom would kill me. and on top of that, i am unemployed, dont have room and all the money i do have is going to doctors for my cancer. Link to comment Share on other sites More sharing options...
