baccaruda Posted May 19, 2007 Share Posted May 19, 2007 My donor engine / harness are a 1990 (3-plug) EJ22. The coolant passage pipe on top of the block has a "Thermometer" with one pole and a "Water Temperature Sender" which has two poles and is brown/red. The WTS deals with both the EJ gauge and the ECU. I can't seem to find where the "Thermometer" goes to. I am going to drill and tap one of those sensors' holes for an EA temperature sender (digidash's idiot light, single pole). M16 thread, 1.5 pitch FYI. I thought I'd read that someone drilled out the WTS hole but as that goes to the ECU, and since I can't see as how the "Thermometer" seems to go anywhere, I wanted to double check what I'd read.. Quote Link to comment Share on other sites More sharing options...
Subarutex Posted May 19, 2007 Share Posted May 19, 2007 The single pole EJ sensor is just for the gauge and idiot light in the legacy. Good luck drilling and tapping... i though about doing that, but decided just to stick with having a temp gauge that is scaled funny. Since both my cars are setup the same, its pretty standard for me now. M16 seems rather large for that area where the sensor is... Take pics! ps.. i got your box Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 19, 2007 Author Share Posted May 19, 2007 wewt for the box. :burnout:dry on low heat only!!!! I had the thought that both of the senders on the EJ looked to have approximately the same sized male end. With what you're saying, I don't need the Thermometer at all.. so I could move the WTS over to the Thermometer's area (you're right, it does have less area in which to comfortably drill and tap) and steal the WTS' old spot for the M16/1.5 EA gauge sender. Unless... do we know how the EJ Thermometer compares electrically to the EA digidash's sender?? That would be neat if I could cheat a little there... Quote Link to comment Share on other sites More sharing options...
Subarutex Posted May 19, 2007 Share Posted May 19, 2007 No idea on the digidash... if you use the SEARCH button you might find another thread where someone used a resistor wired to ground to change the signal curve of the EJ sender for use on a normal EA dash. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 20, 2007 Author Share Posted May 20, 2007 I even got some of the proper resistors but my assumption is that the resistor trick is for an analog dash while I'm running a digi for now.. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted May 20, 2007 Share Posted May 20, 2007 Not a clue as to the digi-dash application of the sensor. BTW which car is this in? Quote Link to comment Share on other sites More sharing options...
suberdave Posted May 20, 2007 Share Posted May 20, 2007 i have an EJ in my GL10 with Digi dash. works awesome. just reads one bar lower than it did with the EA in it... but it never goes into the red like the EJ82t did... -=Suberdave=- http://www.suberdave.com Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 20, 2007 Author Share Posted May 20, 2007 Dave.. that's awesome to know. Looks like less work for me! Do you happen to know how the stock EJ oil pressure light sender compares to the 86 digidash's sender? It would be even better if I had one less sensor to add for now... Bratman, this is in my 86. Quote Link to comment Share on other sites More sharing options...
suberdave Posted May 20, 2007 Share Posted May 20, 2007 yeah the EJ uses a light and the digi dash also uses a light. just hook it up and all is well. its easier than the analog dash that uses a gauge... -=Suberdave=- www.suberdave.com Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 20, 2007 Author Share Posted May 20, 2007 awesome, thanks Dave. I wanted to do the analog dash conversion at the same time i did the rest of the wiring install but I'm dying to get the car on the road - I'm glad I put the analog conversion aside for a while. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 21, 2007 Share Posted May 21, 2007 My donor engine / harness are a 1990 (3-plug) EJ22. The coolant passage pipe on top of the block has a "Thermometer" with one pole and a "Water Temperature Sender" which has two poles and is brown/red. The WTS deals with both the EJ gauge and the ECU. I can't seem to find where the "Thermometer" goes to. I am going to drill and tap one of those sensors' holes for an EA temperature sender (digidash's idiot light, single pole). M16 thread, 1.5 pitch FYI. I thought I'd read that someone drilled out the WTS hole but as that goes to the ECU, and since I can't see as how the "Thermometer" seems to go anywhere, I wanted to double check what I'd read.. I'm pretty sure that just like the EAs, the EJ uses seperate sensors for the ECU and Gauge. Single pole "thermometer" sends signal to the Gauge, "WTS" with 2 poles is for the ECU. EA analog and digidashes use the same sender(thermometer) so the scale is the same. Should be no difference with using it in digi or analog dash. I would think it best to thread the manifold for the right sender, ort at least fix the scale with a resistor. You're EA gauge will never show hot using an EJ sender, you'd be guessing as to how hot your actually running. Basically once it got hot the sender would be far from acurate would stop rising even though the engine is getting hotter and hotter. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 21, 2007 Author Share Posted May 21, 2007 yeah, good point.. I need to find someplace that has the proper tap and nobody open on the weekend had one so I got used to the idea of skipping it but the OPS doesn't bug me at all.. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted May 25, 2007 Share Posted May 25, 2007 I drilled and tapped 2 so far. Both work great. The first one I used an ej22 turbo crossover pipe. I did that because there are 2 sets of places that there is enough metal for sensors...leave the originals in their holes and drill out the 2nd metal tappable areas larger area for the ea sensor. The one I did with a standard pipe was very tedious but still doable. I tapped out the smaller hole for the 2 prong ej22 sensor and the bigger hole for the ea. If you have one, the turbo ea81's have the sensor mounted in the heater hoses. Thats what I am using in my 83 EA81T 2.2 conversion. Mine, thusfar, has run real nice and cool. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 25, 2007 Author Share Posted May 25, 2007 Thanks Shawn. you're saying you moved the red/brown EJ sensor over to where the thermometer should be? that's my plan. I'll look at my turbo coupe's heater hoses later.. thanks. Quote Link to comment Share on other sites More sharing options...
