tidd1340 Posted May 19, 2007 Share Posted May 19, 2007 Doing a timing belt,radiator,water pump,cam seal,oil pump seal,valve cover gasket job this week. Also doing the crank seal(front)Is it easy to do(crank seal)? Link to comment Share on other sites More sharing options...
idosubaru Posted May 21, 2007 Share Posted May 21, 2007 yes and no. it's easy to do, but access is annoying, it's hard to get good solid and even pressure to get it in quickly. get a Subaru crank seal. i installed a Fel Pro seal earlier this year on an EA82 and it wasn't a good fit. didn't seem to want to go in quite right, eventually got it in. ended up leaking horribly in about a month and i replaced it again. the old seal was mangled and definitely not quite the right size...just off enough to cause the sealing edges of the seal to be compromised. the rubber was folded and torn. the new seal went in fine and doesn't leak. have a short piece of PCV pipe the right diameter to help install it. take your time and be patient, sometimes it takes awile of tapping and massaging it in place. other than the cramped space it's not hard. definitely remove the radiator. Link to comment Share on other sites More sharing options...
snoboy Posted May 21, 2007 Share Posted May 21, 2007 Think about doing the camshaft seals while you are in there too. They are actually easier to do than the crankshaft, although they require a bit more stuff to be removed (the timing belt sprockets...) Get the seal retainer O-rings at the same time. IMO, this is a pretty easy job. PVC pipe or pipe fittings is a great tip. I drilled a small hole in the front of the crankshaft seal and threaded a wood screw in there to pull it out. Just be careful not to damage the seat of the seal. Study the new seal to see what you will be drilling. Link to comment Share on other sites More sharing options...
tidd1340 Posted May 21, 2007 Author Share Posted May 21, 2007 Both great advice..thanks! Link to comment Share on other sites More sharing options...
