pinksock Posted May 23, 2007 Share Posted May 23, 2007 Yes, I'm in the middle of EA82-EJ22 swap. Me question is, now that its getting HOTTER here in BOISE IDAHO, the more and more I want to keep the A/C unit in this swap. I wanted to know if the A/C unit off the EA82 would bolt up to the EJ22 motor or if it could be modified sensibly to work with the EJ22?? I have the A/C unit off of the EJ22, but I dont know if it works?? The A/C unit in my EA82 blow SUPER COLD!!!! So if I could use that one that would be great. One more question, if I have to use the A/C unit off the EJ22 will the hoses from the EA82 work on the EJ22 A/C unit?? Thanks For the Help Guys:) Tony Link to comment Share on other sites More sharing options...
pinksock Posted May 24, 2007 Author Share Posted May 24, 2007 Anyone have any idea?? Link to comment Share on other sites More sharing options...
bratsrus1 Posted May 24, 2007 Share Posted May 24, 2007 Hey Tony This is Jerry, you will need to use the 2.2 pump because of the belts they are different. Drain the system and have 2 new hoses made with the 2.2 ends on end and have the EA82 ends on the other that way it will bolt back up. Recharge the system Thanks Jerry Link to comment Share on other sites More sharing options...
pinksock Posted May 24, 2007 Author Share Posted May 24, 2007 Thanks that what I thought, just wanted to do it the easy way. Hey Tony This is Jerry, you will need to use the 2.2 pump because of the belts they are different. Drain the system and have 2 new hoses made with the 2.2 ends on end and have the EA82 ends on the other that way it will bolt back up. Recharge the system Thanks Jerry Link to comment Share on other sites More sharing options...
baccaruda Posted May 25, 2007 Share Posted May 25, 2007 that is the easy way Link to comment Share on other sites More sharing options...
