porcupine73 Posted May 24, 2007 Share Posted May 24, 2007 Here's what happens when you attempt to install the wrong Whiteline rear endlinks (KLC026) on an '00obw. It sort of looks OK when the vehicle is jacked up. But when lowered, the axle shafts rub on the end link, as shown in the pic below. You can hear it rub the half shaft when moving the vehicle. Whoops. I'm not sure how I ordered these wrong end links and/or why I thought they would fit this '00obw when they looked completely different than stock and the Whiteline installation pic didn't look at like what I had. Hopefully I will get the correct KLC044 tomorrow. I believe I can use these endlinks though on my '96 Legacy. Fortunately I resisted the desire to 'trim' these end links. Quote Link to comment Share on other sites More sharing options...
jamal Posted May 24, 2007 Share Posted May 24, 2007 I don't know if those endlinks will work with the 00+ multi-link, and on top of that they're backwards. The 'C' faces toward the rear of the car. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted May 24, 2007 Author Share Posted May 24, 2007 Thanks Jamal. Yes these endlinks will not at all work on the '00obw. I ordered the wrong endlinks. It is maybe possible that with a little 'trimming' they would work but I don't want to do that. They can't be installed the other way because there is some suspension piece in the way. It's like a tubular piece, not a rod like in your pic. Your pic does match the Whiteline pic for this installation though. Ordered the correct endlinks from RenickMotorsports.com today via overnight so hopefullly I get them for the long weekend! Front endlinks installed great. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted May 26, 2007 Author Share Posted May 26, 2007 Problem fixed. I probably should have gotten a bigger rear sway bar while I was in there.... 1. Ordered correct endlinks (Whiteline KLC044 swivel): 2. Installed correct endlinks: The fronts went in without issue. Quote Link to comment Share on other sites More sharing options...
Kilroy Posted May 26, 2007 Share Posted May 26, 2007 Do you feel a lot of difference over the stock setup? Quote Link to comment Share on other sites More sharing options...
jamal Posted May 26, 2007 Share Posted May 26, 2007 I noticed a big difference but I changed my front swaybar and put in urethane swaybar bushings at the same time. From what I've heard lately the endlinks, even the plastic rear c-links, don't flex all that much. Either way the car settles into corners right away and is quicker to change direction. They do break sometimes with bigger bars though, which is a better reason to upgrade. Quote Link to comment Share on other sites More sharing options...
