abcus Posted May 25, 2007 Share Posted May 25, 2007 I just bought an 89 wagon. Is there a way I can get the hood open by myself? If I had help they could pound on it . The knob inside seems to pull normally. Thanks, abcus Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 25, 2007 Share Posted May 25, 2007 I just bought an 89 wagon. Is there a way I can get the hood open by myself? If I had help they could pound on it . The knob inside seems to pull normally.Thanks, abcus Pull harder. Quote Link to comment Share on other sites More sharing options...
Skip Posted May 25, 2007 Share Posted May 25, 2007 pry up one corner of the hood with a piece of softwood (pine ect) just enough to apply pressure. pull cable. If no luck try the other side. Quote Link to comment Share on other sites More sharing options...
zyewdall Posted May 25, 2007 Share Posted May 25, 2007 I suspect the catch isn't staying uncatched after you pull the cable -- you need to pull the cable, and then try to lift the hood while holding the cabled pulled out. What I do sometimes when I encounter this is to put a set of vicegrips on the pull to keep it out, then go out and lift the hood. Z Quote Link to comment Share on other sites More sharing options...
abcus Posted May 28, 2007 Author Share Posted May 28, 2007 Thanks for the help, I used a piece of wood under the hood and it worked. Thanks, abcus pry up one corner of the hood with a piece of softwood (pine ect) just enough to apply pressure. pull cable. If no luck try the other side. Quote Link to comment Share on other sites More sharing options...
Skip Posted May 28, 2007 Share Posted May 28, 2007 You're welcome and thank you for the follow up. We need more people like you to follow up on suggs given, good or bad. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted May 28, 2007 Share Posted May 28, 2007 wasnt there a thread about a year back talking about follow ups? I agree more people need to follow up. Quote Link to comment Share on other sites More sharing options...
NuclearBacon Posted May 29, 2007 Share Posted May 29, 2007 You're welcome andthank you for the follow up. We need more people like you to follow up on suggs given, good or bad. I AGREE!!!!!!! i went through just recently and searched for my username, then updated ALL my unclosed posts. I HIGHLY RECCOMMENDED IT!!!!! Quote Link to comment Share on other sites More sharing options...
