lekmedm Posted May 30, 2007 Share Posted May 30, 2007 Hey all, I recently bought an '06 Outback XT LTD with the OEM Navi installed. The Navi has one downside that gets to me. It won't let you program destinations while the car is moving. Now, I know this is a safety feature, but what a PITA!!! It's just not practical while on the road to pull over every time you want to program something in. Does anyone know of any way to get around this and disable this feature? I've been reading a thread on legacygt.com about this, but they haven't come up with anything yet. Link to comment Share on other sites More sharing options...
Legacy777 Posted May 30, 2007 Share Posted May 30, 2007 I'm sure it puts the nav into lockout when the car receives a speed signal. Removing the signal won't work since the nav needs it. Short of a programming change, I don't think you'll be able to get around it. Link to comment Share on other sites More sharing options...
gbhrps Posted May 30, 2007 Share Posted May 30, 2007 The same is true for my wife's Lexus, while the car is in motion you can not program another destination. I drive an 07 OBW LTD without navigation, and recently purchased a portable Garmin nav unit. Because it is portable, can be removed from the car, and can even be used while walking (has an 8 hour battery backup), it can be programmed while moving. But I would have the passenger do the programming while on the road, since even the slightest driver distraction can have terrible consequences. Its not worth taking the chance to save some time, and then possibly paying for it for the rest of your life. Link to comment Share on other sites More sharing options...
jib Posted June 1, 2007 Share Posted June 1, 2007 That's odd. Our Volvo XC90 has a remote control that even a rear seat passenger can use to program the NAV. Also, there is a set of controls on the sterring wheel for programming it. One difference though, the Volvo NAV system's screen rises up, out of the top of the dashboard, so it's high up and very close to your natural field of view. Jack Link to comment Share on other sites More sharing options...
nipper Posted June 1, 2007 Share Posted June 1, 2007 When there are steering wheel controls, you can set it in motion. Thats pretty much the standard. nipper Link to comment Share on other sites More sharing options...
Hondasucks Posted June 2, 2007 Share Posted June 2, 2007 They need to put a set of controls out of reach of the driver, so at least the passenger can enter stuff... I wonder if it's linked to the speed signal.. Does it work if the car is stopped, but in drive? I discovered on hackaday.com how to put an OnStar box into NMEA mode and plug it into a laptop to get the GPS signal :-P I bet it won't be much longer before there is a navigation hack for this... Link to comment Share on other sites More sharing options...
nipper Posted June 2, 2007 Share Posted June 2, 2007 They need to put a set of controls out of reach of the driver, so at least the passenger can enter stuff... I wonder if it's linked to the speed signal.. Does it work if the car is stopped, but in drive? I discovered on hackaday.com how to put an OnStar box into NMEA mode and plug it into a laptop to get the GPS signal :-P I bet it won't be much longer before there is a navigation hack for this... of course its hoooked up to the speed signal. In car units are wired into the vss system so they can do some dead reconing when they use the satalite, along with the wheel angle sensor. put the car in drive with the wheels chocked and no foot on the brake. This will tell us if it is wired into the NSS or not. Try to fiddle with it then. nipper Link to comment Share on other sites More sharing options...
hklaine Posted June 2, 2007 Share Posted June 2, 2007 Do these super-modern Subarus use CAN? Do you know who makes that system? Link to comment Share on other sites More sharing options...
Legacy777 Posted June 4, 2007 Share Posted June 4, 2007 Do these super-modern Subarus use CAN? Do you know who makes that system? Yes the newer subarus, legacies & Outbacks for sure do use CAN. Link to comment Share on other sites More sharing options...
lekmedm Posted June 19, 2007 Author Share Posted June 19, 2007 Well, if anyone is interested, someone over at legacygt found a very simple and elegant solution to unlocking the navigation lockout while driving. Have a look http://www.legacygt.com/forums/showthread.php?t=63678 Link to comment Share on other sites More sharing options...
