'91 EJ22 installed in my vanagon has been running code free for more than a year. CEL came on the other day - flashing 22. Finding the knock sensor cracked, I picked up and installed a new one, thinking this was a pretty straight-forward issue. Unplugged the ECU overnight to clear codes, hooked everything back up and......still flashing 22. What's up? Do I need to do something else to completely purge the code from my ECU, or is there still come issue with the Knock Sensor or it's circuit? The wiring seems fine, connection between the harness and the sensor seems solid. What am I missing?
Just did some additional searching an noted that exposed wire could cause the code - the plastic part of the male side of my plug seems to be missing and the connector is a bit exposed - maybe this is my problem? Considering clipping the plug on both ends and replacing with a simple paddle connector?
Thanks much in advance for your thoughts!
