SoobGoob Posted May 30, 2007 Share Posted May 30, 2007 ok so i searched and couldnt find anything spefic for my car. so sorry to repeat a question asked a million times. but i have some 205/75 R13's on some chevy lugs and they are already drilled. can i fit them on myloyale with minimal or no cutting in the rear. i dont mind cutting the front. any help? Link to comment Share on other sites More sharing options...
Turbone Posted May 30, 2007 Share Posted May 30, 2007 You did read the sticky at the top of the page? http://www.ultimatesubaru.org/forum/showthread.php?t=62289 And why would you put 13's on a chevy lug wheel? Link to comment Share on other sites More sharing options...
Phizinza Posted May 31, 2007 Share Posted May 31, 2007 If they are 13's and not 14's then they should fit no worries. Ofcause it all depends on the wheels offset...... 205/75R13 is 25.1", plus an inch if you ment 14's... Link to comment Share on other sites More sharing options...
SoobGoob Posted May 31, 2007 Author Share Posted May 31, 2007 yes turbone that was the first i checked. wasnt spefic enough. and they were on 13 chevy redrilled rims. 25.5 inches across. (got them for free) but after a day of cutting and pounding in 90 degree weather i got them all to fit with no rubbing. now i just need something to put where i cut the fender. any ideas? pics soon to come. its looks great even with no lift. very excited Link to comment Share on other sites More sharing options...
Phizinza Posted May 31, 2007 Share Posted May 31, 2007 SoobGoob said: now i just need something to put where i cut the fender. any ideas? .. Paint? Link to comment Share on other sites More sharing options...
SoobGoob Posted May 31, 2007 Author Share Posted May 31, 2007 haha no i meant some sort of plastic trim. the cut was not a perfect shape and i dont like the sharp edge there so im looking for something to make it look a little cleaner Link to comment Share on other sites More sharing options...
SoobGoob Posted June 1, 2007 Author Share Posted June 1, 2007 les schwab wouldnt alinge my tires!?! because "they were too big" so now i have to swap the stock ones on to get an alingment. what a joke:dead: Link to comment Share on other sites More sharing options...
SoobGoob Posted June 1, 2007 Author Share Posted June 1, 2007 with the new tires on my car kind of shakes? i dont know the best way to put it. bouces slilghtly? could this be off balance tires. also it pulls more to the left then before i knew the alingment was off already but is it just more noticeable with larger tires? basically what im asking is if these are problems that can be taken care of with alingment and balancing? and is there anyway to make my suspension stiffer/longer? my rears run close to the well and i know one big bump would make them rub with my worn out suspension... Link to comment Share on other sites More sharing options...
SoobGoob Posted June 1, 2007 Author Share Posted June 1, 2007 i heard something about honda springs? Link to comment Share on other sites More sharing options...
P K Posted June 1, 2007 Share Posted June 1, 2007 Whoa, stop the press. Where do you get 205/75-13 tires? Do you have a pic? Thanks, r/PK Link to comment Share on other sites More sharing options...
SoobGoob Posted June 1, 2007 Author Share Posted June 1, 2007 they are some wildcats GD traded me last summer. i dont know where he got them Link to comment Share on other sites More sharing options...
SoobGoob Posted June 1, 2007 Author Share Posted June 1, 2007 correction i went to take pictures they are 14s. sorry for the typo. but i decided im just going with the sjr lift. WHOOHOO Link to comment Share on other sites More sharing options...
chazmataz Posted June 2, 2007 Share Posted June 2, 2007 bigger tires then stock shouldn't have stopped les schwab from doing an alignment. i have never heard of that. what les schwab was it?????? you come to my store and i'll align it for you, unless you have wornout parts then they would have to be replaced. an alignment won't always stop a car from pulling, other things can cause a pull to. mine pulls i just live with it because i've mod the piss out of it and i'm running 15". Link to comment Share on other sites More sharing options...
Turbone Posted June 3, 2007 Share Posted June 3, 2007 I'm not sure (I havent had a alignment in over 20yrs) but maybe the new setups are computerised and when you punch in 14in tires for a Subaru for the car info it comes up with a error. Link to comment Share on other sites More sharing options...
Phizinza Posted June 6, 2007 Share Posted June 6, 2007 I use a tape measure and align myself. What can they really align on a stock EA82?? Steering is about it. Not hard to do it yourself really. Link to comment Share on other sites More sharing options...
