Uberoo Posted June 9, 2007 Share Posted June 9, 2007 What are some springs that would fit on the front of an EA82 that would life the front end 1 1/2-2"?I could make spacers to space the bottom of the strut away from where it mounts to arm But this is something to be temporary... Link to comment Share on other sites More sharing options...
Uberoo Posted June 9, 2007 Author Share Posted June 9, 2007 Do legacy DOjs fit on EA82 axles?If so us Ea82 guys would have stretchy axles just the EA81 guys with dual EA82 DOJs...Im thinking dual legacy DOJs on the rear... Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 9, 2007 Share Posted June 9, 2007 I haven't heard of that being tried yet. You must be the one to give it a shot, lol... Link to comment Share on other sites More sharing options...
ezapar Posted June 10, 2007 Share Posted June 10, 2007 What are some springs that would fit on the front of an EA82 that would life the front end 1 1/2-2"?I could make spacers to space the bottom of the strut away from where it mounts to arm But this is something to be temporary... Ya do know that you can get adjustable struts for those. They come with a natural 1 and 1/2 inch of lift. . . Camber suffers though. Link to comment Share on other sites More sharing options...
Uberoo Posted June 10, 2007 Author Share Posted June 10, 2007 I thought EA82 didn't get adjustable struts...But if they did get them where can I find some... Link to comment Share on other sites More sharing options...
Numbchux Posted June 10, 2007 Share Posted June 10, 2007 '85 and '86 4WD models. hard to find replacements for though... RX springs have a higher spring rate, and will yield a bit of lift in the front as well. Link to comment Share on other sites More sharing options...
Uberoo Posted June 10, 2007 Author Share Posted June 10, 2007 I think I will try to find an 85-86 4wd then,RX's are hard to find...Although if I could find a 85-86 4wd RX then I would be set.I could have a winch/bumper and not have sagging springs.. Link to comment Share on other sites More sharing options...
El Toro Posted June 12, 2007 Share Posted June 12, 2007 some one once said front springs from a ford tempo gave 1.5in lift plus a softer ride. still waiting for one to come through my local jy to see if its true. Link to comment Share on other sites More sharing options...
chazmataz Posted June 12, 2007 Share Posted June 12, 2007 when i checked ( a year ago) you could still get new factory kyb"s with the adjustable lower spring perchs from subaru, roughly around 150-175 per strut. unfortunately you can't buy them from anywhere else that way, kyb is contracted by subaru to make those struts for them. i got info straight from the tech department at kyb when i ordered some from kyb and came through with the fixed perchs. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 9, 2010 Share Posted December 9, 2010 some one once said front springs from a ford tempo gave 1.5in lift plus a softer ride. still waiting for one to come through my local jy to see if its true. That was me... ...I Said that. For more info about it, see this Thread: http://www.ultimatesubaru.org/forum/showthread.php?t=110546 Kind Regards. Link to comment Share on other sites More sharing options...
Gloyale Posted December 9, 2010 Share Posted December 9, 2010 Do legacy DOjs fit on EA82 axles?If so us Ea82 guys would have stretchy axles just the EA81 guys with dual EA82 DOJs...Im thinking dual legacy DOJs on the rear... Yes it works....this is what I have on the rear of my EA81 Has to be Legacy rear axle inner joint DOJs so they will be 23 spline. Also, EA82 front axle DOJ and rear inners DOJ will also work for the same, although they aren't quite as deep as the Legacy ones. Link to comment Share on other sites More sharing options...
Uberoo Posted December 14, 2010 Author Share Posted December 14, 2010 hmmm, EA81 axles with legacy DOJ's = MEGA Stretchy axles.... wheel travel FTW! Link to comment Share on other sites More sharing options...
