Driveline HELP!!!!!
I have an 89 DL wagon and the U joint is worne out in the very rear, I was wondering if I could take the back half of the driveline out and drive the car like that till I can get a replacement? It has the 2 piece driveline Thanks a bunch for your help
Yes, that works fine. I had the same problem once and removed the rear section of the driveline for a temp fix.
  grossgary said:
so long as you have a working center differential lock it will work fine. a PT4WD trans or locking center diff full time 4WD box will do it.
I'll let him answer
DL is the base, base model, almost no options. Only available with PT 4wd
