TROGDOR! Posted November 30, 2003 Share Posted November 30, 2003 I've heard from some people that all 4 cyl XT's have a 3.7 final drive. I've heard from other people that the nonturbos have 3.9, just like sedans and wagons. So, which is true- do they all have 3.7? And if they all have a 3.7 final drive- are the transmissions the same as a turbo? The reason I ask is because I have a bad CV joint on an 88 2WD XT with a manual, and I really need to know if it's a 23 spline or a 25 spline. Link to comment Share on other sites More sharing options...
mudrat79 Posted November 30, 2003 Share Posted November 30, 2003 Morning.... Your XT being 2WD ,5 speed, Non-Turbo, Should have a 23 spline axles..... Auto may have 25, I personally have never delt with 2WD Auto on one yet...... Hope it Helps, As always, once you have the fresh axle stuff it on the trans first before install just to be double sure...... Later, John in Oregon.... Link to comment Share on other sites More sharing options...
MilesFox Posted November 30, 2003 Share Posted November 30, 2003 all the autos except for full time turbo have 23 splines. jim's 4wd xt turbo had a bad diff, and we swapped in a 2wd auto that fit the same Link to comment Share on other sites More sharing options...
86subaru Posted November 30, 2003 Share Posted November 30, 2003 but tranny is out again, also rear diff, ,because i could not get a title for the car , Link to comment Share on other sites More sharing options...
