91 Loyale ECU gives 6 short pulses only
If I'm reading the USRM correctly, I should be seeing (if anything) a number of long pulses followed by a number of short pulses. This is a key-on, no connectors test.
6 short pulses, pause, 6 short pulses, ad infinitum. No timing changes, no pause changes. Just 6 short.
Any insights?
Kalo:confused:
Originally posted by NorseKode
Actually, it looks as if it may cost quite a lot to fix the California thing.
:D
Thanks for the lookup.
Kalo
CA models are a little different..for example, My motor is from a California car.. it had no EGR.. so when it went into another car, I had to swap intakes.. and suddenly it has an EGR!!.. but no hole in the drivers side head to attach the EGR pipe:rolleyes:
