rzirker Posted June 13, 2007 Share Posted June 13, 2007 99 Manual trans is shot. They are hard to find and pricey. Can I rig a 98 Forester 5-speed or an 00-01 5 speed tranny into it?? There are lots of them and they're cheap. Maybe have to take 4 of the engine bolts out? Anyone tried swapping one out? Swap swap. Thanks for any ideas. Link to comment Share on other sites More sharing options...
SuBrat84 Posted June 14, 2007 Share Posted June 14, 2007 In the 99 (motorswap) I did it only had 4 bolts anyway.. you've got my vote that the trannies will swap.. especially since it's a manual. Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 14, 2007 Share Posted June 14, 2007 The tranny should swap out. You will have to contend with the 8 bolt v. 4 bolt though. Make sure the final drive matches as well. If you can't verify get the rear diff as well. Link to comment Share on other sites More sharing options...
rzirker Posted June 14, 2007 Author Share Posted June 14, 2007 The tranny should swap out. You will have to contend with the 8 bolt v. 4 bolt though. Make sure the final drive matches as well. If you can't verify get the rear diff as well. Which tranny? Down to a 98 or up to 00-01? Rear diffs are all the same ratio. Thanks. Link to comment Share on other sites More sharing options...
DerFahrer Posted June 14, 2007 Share Posted June 14, 2007 The tranny out of a 98 Forester should be 4-bolt. Everything past that should be an 8-bolt. Link to comment Share on other sites More sharing options...
idosubaru Posted June 14, 2007 Share Posted June 14, 2007 make sure the final drive ratio didn't change between years either. probably didn't, but you want to be sure. Link to comment Share on other sites More sharing options...
rzirker Posted July 10, 2007 Author Share Posted July 10, 2007 Put a 2000 5-speed in and it worked fine. So glad. Rear end is the same in all Foresters through '04. Also want to mention an engine swap that a friend did, 95 2.2 into a 98 Forester, worked fine too. Noticable lack of pep though. Thanks for the comments and suggestions. Link to comment Share on other sites More sharing options...
