mikekucharski Posted December 1, 2003 Share Posted December 1, 2003 Hello all! This is my first post, and Im new to working on cars. I have a 92 loyale wagon, 2wd, no turbo, and was wondering if the clutch is hydraulic or dry. also how can i check it if it's hydraulic? In addition I need to buy a new pilot bearing, but haven't gotten a chance to take the old one out yet. Is the pilot bearing a sealed or unsealed bearing? Also any tips anyone has for changing a clutch such as engine support methods would really help me out.. Thnaks again, hopefully Ill be talking to you all soon... Mike Link to comment Share on other sites More sharing options...
stephenw22 Posted December 1, 2003 Share Posted December 1, 2003 The clutch isn't hydraulic. It might look like it, because of the 'hill holder' that attaches to the clutch with a cable. The hill holder prevents the car from rolling back when it's in a forward gear with the clutch depressed. The pilot bearing should be sealed. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 1, 2003 Share Posted December 1, 2003 Easiest to either remove the engine, or the transmission from the car. Might as well change the rear main seal while your in there - cheap and easy to do. Don't want any oil on that pretty new clutch. If you can, rent an engine hoist for a day. This can make the job a LOT easier. Pull out the radiator, then the engine - do he clutch, then put it back. Should be able to do it in a day if you have all the parts. Maybe two days if you need the flywheel turned too. Another thing - when installing the enigine back into the car, place a jack under the tranny, and jack it up a few inches. Place the tranny in 4th gear, and put a breaker bar and socket on the crank pully bolt. Turn the crank while inserting the engine onto the transmission shaft. Will go in much quicker if you use this method...... credit goes to Qman for this method of installation. GD Link to comment Share on other sites More sharing options...
baccaruda Posted December 1, 2003 Share Posted December 1, 2003 however, you can convert to a hydraulic clutch if you want to. the pilot bearing is sealed, and you can get one at many places. some people here advocate using subaru dealer parts whenever possible.. i'm not sure if the pilot bearing is one example, but when i do a clutch i go to the dealer to buy two new throwout bearing clips. they're so cheap that there's no excuse in my book not to use a brand new one. who wants to do another clutch job just to replace an old broken pin? anyway, i usually get my pilot and TO bearings in the same trip to the dealer as the clips. this is also a good time to check your clutch cable and check the boot for the clutch fork that surrounds it where it exits the top of the transmission.. those get torn up with age and why not do it all at once? don't forget to have the flywheel resurfaced too. if you go thru the archives or the USRM (ultimate subaru repair manual) there have already been a few write ups on how to do a clutch job. good luck! Link to comment Share on other sites More sharing options...
JWX Posted December 1, 2003 Share Posted December 1, 2003 how can we convert to a hydraulic clutch? I've never heard of somebody doing this and was thinking about it the other day when my clutch cable snapped. Link to comment Share on other sites More sharing options...
baccaruda Posted December 1, 2003 Share Posted December 1, 2003 why 4th gear specifically? sounds like a neat idea though. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 1, 2003 Share Posted December 1, 2003 Other gears will work too - Ken said he prefered 4th - not sure why - I asked the same question...... don't recall getting a good anwer other than "I like 4th" ok........ GD Link to comment Share on other sites More sharing options...
mikekucharski Posted December 1, 2003 Author Share Posted December 1, 2003 thanks a lot guys... Im still rounding up parts... one more question for now... is a through out bearing the same as a release bearing? thanks again, hopefully Ill be able to start on it friday. Link to comment Share on other sites More sharing options...
mlambie Posted December 21, 2003 Share Posted December 21, 2003 Mike, you can either make an engine support bracket or buy one pretty inexpensive. I made mine out of 2" gas line pipe and some chain and turnbuckles. If you want more detail let me know. But I found one at Performance Tool for $40 and I think it would have been smarter to have paid that instead of making it, especially at that price. I checked our tool rental place that normally has stuff like this but they did not have it but they did have a transmission jack that could be rented for about $25 a day. Not too bad. Mike Link to comment Share on other sites More sharing options...
Nug Posted December 21, 2003 Share Posted December 21, 2003 Pilot bearing and throwout bearing are 2 different animals. As for 4th gear, it's harder to move the car in forth. You'll run over your feet in first. Link to comment Share on other sites More sharing options...
RedNed Posted December 22, 2003 Share Posted December 22, 2003 The pilot and throw-out bearings are different but the throw-out and release bearings are the samething. As for converting to hydrualic...Why? The hydrualic clutch on my BroncoII(I know issues to begin with) was nothing but a pain in the a**. Non-adjustable, the throw is different each time you turn the flywheel, master and slave cylinders tend to wear and leak. You have to flush the system more often then the brakes if you do any fjording. I can understand for a large truck were the clutch pressure is hard on the leg but I'm much happier with the cable clutch on my Sube. Link to comment Share on other sites More sharing options...
