backwoodsboy Posted June 20, 2007 Share Posted June 20, 2007 Here she is folks! - Removed the shift rod from the tranny, and bent it out of the way. - Welded a bolt (with matching thread, and connected to tranny, onto the end of a spare ea81 hood prop rod - Routed rod through drilled hole in firewall. - Connected to spare 4WD hi/lo shift assembly, which was welded to the body. PICS!!! Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 20, 2007 Share Posted June 20, 2007 Very nice. Good work. Link to comment Share on other sites More sharing options...
Sweet82 Posted June 20, 2007 Share Posted June 20, 2007 I like your engineering... The stick is backwards from the factory position, so are you pushing down for 4wd up for 2wd:confused: Link to comment Share on other sites More sharing options...
backwoodsboy Posted June 20, 2007 Author Share Posted June 20, 2007 I like your engineering... The stick is backwards from the factory position, so are you pushing down for 4wd up for 2wd:confused: The blue factory-position stick you see in the corner of picture 2 now ONLY controls the 2wd/4wd action. The new tan stick I put in is to select hi or lo range independently of the 4wd ......lemme tell you, 2wd lo is SWEET if you are running bigger tires! UP is high-range DOWN is low-range I had to weld it in backwards too.....if it was the "right way" it would be in the way. Where it is, it tucks nicely behind your knee as you drive! Link to comment Share on other sites More sharing options...
s'ko Posted June 20, 2007 Share Posted June 20, 2007 NICE work. Super easy mod huh? I guess no one ever thought of it before now. lemme tell you, 2wd lo is SWEET if you are running bigger tires! X2.... Link to comment Share on other sites More sharing options...
