mattb43 Posted June 20, 2007 Share Posted June 20, 2007 I have a 1986 Subaru XT GL-10 Turbo and my running lights are acting up. Heres the issue. When I press the running light button the running lights work just fine. When I press my headlight button the running light button on the dash clicks off (basically the two switches cant be pressed at the same time). Brake lights and everything works fine. So when the headlight button is on the running lights are off. I was pulled over for not having them on so any help would be appricated. Thanks, Mattb Link to comment Share on other sites More sharing options...
Turbone Posted June 20, 2007 Share Posted June 20, 2007 Check the switch thats on top of the steering column, it might be on. Link to comment Share on other sites More sharing options...
joostvdw Posted June 20, 2007 Share Posted June 20, 2007 you're getting pulled over for having your headlights on but not your running lights :-\ that's odd other than that, the running lights should come on with your headlights, if you're really desperate you could run a relay to the running lights and use the headlights as a signal for the relay, but not after you've done the test and advices to come :-p Link to comment Share on other sites More sharing options...
mikeshoup Posted June 21, 2007 Share Posted June 21, 2007 It sounds like the switch pod may be broken. Your running lights should stay on when you hit the headlight switch (the running light switch will pop back out). The only thing I could think of would be the switch pod. Link to comment Share on other sites More sharing options...
Gloyale Posted June 21, 2007 Share Posted June 21, 2007 you're getting pulled over for having your headlights on but not your running lights :-\ that's odd I think he means the tail lights, as well as the front marker lights. There is a tail light relay. Blue connector, I'm assuming under dash. It get's power from the fusible link and supplies power to fuse 7 in the box. Check both of the fuses and the links. The *passing switch*(that's what the FSM calls it) switch is suppllied with power from fuse 4, so it would work even when the other circuit has blown a fuse/link/relay, etc. Link to comment Share on other sites More sharing options...
