AA Wheels?
I noticed mention of these wheels on here doing a search for wheels and i was wondering if there is a site for them to look at these wheels...also what needs to be done to a Chevy wheel to adapt it to my DL?
http://alliedarmament.homestead.com/Wheels.html
They do a sale here every once in a while. I had a couple sets, but ended up going the drilled route then the pug route. They are nice and tough but a little spendy for my taste.
The way i drilled mine out was I took a couple old hubs and pressed out two of the studs across from each other then then bolted them to the rims and drilled from the back side with a drill bit that was the same size as the hole the stud was. That way it lines it up for you and there really isn't any way of messing it up. I then counter sunk the hole (i think that's what it's called) so the lug nut would fit in and keep it centered.
