testy Posted June 21, 2007 Share Posted June 21, 2007 Im looking for a photo or two of the underside of a ea82 with the front axles removed and set up for rwd. More or less I want to see what part of the axle was put back in. My terms arent great so I dont really understand when its explained to me. Thanks. Link to comment Share on other sites More sharing options...
Phizinza Posted June 21, 2007 Share Posted June 21, 2007 Sorry, can't help with the photo, but... The part that goes through the hub (which the wheel is bolted to.) It is needed to hold the bearings in place. The rest can go. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 21, 2007 Share Posted June 21, 2007 Its pretty much the same for EA81 and EA82. I wish i had pix, but i dont. I should do a write-up on the process. Pretty much all you do is break your CV (yeah, break it). Remove the shaft from the stub that goes through the steering knuckle. You just re-install the stub and drive your car in 4WD. The tranny output shafts will stay exposed and no CV will lead to the knuckle. The tricky part is seperating the axle shaft from the CV stub. -Brian Link to comment Share on other sites More sharing options...
phillupmacrevis Posted June 22, 2007 Share Posted June 22, 2007 nice, so when run like this all the time...is it bad for the driveline.....basically it can be drifted now right...? lol:clap: Link to comment Share on other sites More sharing options...
Phizinza Posted June 25, 2007 Share Posted June 25, 2007 Drifting is going to be bad for any car and parts... Same with burnouts. If you drive it "saftly" it will be fine I have heard. If you run a rear LSD it should be ok too, but the LSD puts more strain on all of everything. Link to comment Share on other sites More sharing options...
