Rooster2 Posted June 21, 2007 Share Posted June 21, 2007 I have a 98 Legacy Outback, the check engine light code said I need a new knock sensor, so I bought one. The Haynes Subaru manual says that I need to remove the intake manifold on passanger side of engine to gain access to install the new sensor. Is this true? Man that is a lot of work for such a small sensor with an electrical pig tail. Is their an easier way to install? Any advise will be appreciated. Thanks! Link to comment Share on other sites More sharing options...
nipper Posted June 21, 2007 Share Posted June 21, 2007 Do a search here, its really quite simple to replace. nipper Link to comment Share on other sites More sharing options...
Turbone Posted June 21, 2007 Share Posted June 21, 2007 Reply no longer relavent Link to comment Share on other sites More sharing options...
Anthenium Posted June 21, 2007 Share Posted June 21, 2007 I'm seaching as well...Just triggered the Code last night.:-\ Link to comment Share on other sites More sharing options...
Skip Posted June 21, 2007 Share Posted June 21, 2007 I just want to remind you fellows that at the bottom of this page you will find "Similar Threads" They can take the pain out of searching. Hope this helps Link to comment Share on other sites More sharing options...
biglittledog Posted June 21, 2007 Share Posted June 21, 2007 It's pretty easy. Socket and extension gets it out. Buy a low range torque wrench to put the new one in. Cheap at places like Harbor Freight Tools. Then you won't crack the new one in 6 months. Link to comment Share on other sites More sharing options...
weddes05 Posted June 21, 2007 Share Posted June 21, 2007 You can deffinately go straight down the drivers side rear of the intake manifold with a long extension and a 12mm socket Link to comment Share on other sites More sharing options...
Anthenium Posted June 22, 2007 Share Posted June 22, 2007 I just want to remind you fellowsthat at the bottom of this page you will find "Similar Threads" They can take the pain out of searching. Hope this helps Well you learn something Everyday! Fat Tony - Olde Dogg Link to comment Share on other sites More sharing options...
