s'ko Posted June 22, 2007 Share Posted June 22, 2007 I pulled my CEL lights and for now I am getting code 12 which is starter switch or circuit. I have the starter set up w/the BRAT starter circuit. So the engine management is seperate from the BRAT harness. How are other people setting up their starters? Should I take the wire from the starter switch and hook it up to the starter and see if the code clears? I need to clear codes b/c I have to pass smog emissions testing. BW Link to comment Share on other sites More sharing options...
s'ko Posted June 23, 2007 Author Share Posted June 23, 2007 I took a wire and spliced it into the wire from the starter and connected it to the wire to the ECU. Problem gone. BW Link to comment Share on other sites More sharing options...
Phizinza Posted June 24, 2007 Share Posted June 24, 2007 That's what I done Link to comment Share on other sites More sharing options...
