stickedy Posted July 2, 2007 Author Share Posted July 2, 2007 So, my buddy managed to solve the problem! This Transistor was damaged: It's original a NPN transistor, type NEC 2SC2719, and this type isn't in production any more since several years. But you can just use a more common type with the same or better technical datas, so my buddy choosed a BD139 as replacement. This is a very standard type and available from nearly every semiconductor company, for example Texas Instruments, STM, Motorola/Freescale, Fairchild, Siemens, Philips and so on. Here are a few datasheets for BD139: http://www.alldatasheet.com/view.jsp?Searchword=BD139 Anf here is a document which describes the original one: http://www.datasheetarchive.com/datasheet.php?article=3746501 As you can see, the BD139 is far better, but because it's such a common part, it's really cheap. One piece cost about 0.50 US$ here in Germany. The replacement is easy, you can do it with basic soldering knowledge. So, the ECU now works fine as it should! I write an article for the USRM in within the next hours! AND: My problems regarding acceleration are gone!! So it seems that the ECUs interchangeable to some degree and the engine should run, but it runs bad. The test drive was a real pleasure Link to comment Share on other sites More sharing options...
Cougar Posted July 3, 2007 Share Posted July 3, 2007 Thanks for the update. That is the same exact thing that happened to mine though I had a different model ECU. Glad you got it corrected. This will help some others that have the same problem. Can you tell us what the Q number is of the transistor? You can't see what the number is in the pictures. Link to comment Share on other sites More sharing options...
stickedy Posted July 4, 2007 Author Share Posted July 4, 2007 Of course: It's Q701! I forgot to mention it... I made the article: http://www.ultimatesubaru.org/forum/showthread.php?t=76906 I hope this will help other people, too Link to comment Share on other sites More sharing options...
idosubaru Posted July 4, 2007 Share Posted July 4, 2007 that is awesome! thanks for posting all of that information. based on the all that i've read and we've talked off-line i can almost gaurantee this is my issue as well with mine. thanks! that is a fantastic write up! i'm an electronic idiot and it all made perfect sense! thanks again. Link to comment Share on other sites More sharing options...
Gloyale Posted July 4, 2007 Share Posted July 4, 2007 Sweet man! This is a hugely valuable addition to the USRM Link to comment Share on other sites More sharing options...
TPain Posted March 4, 2012 Share Posted March 4, 2012 Do you have a pic of where that transistor is located? I'm having the same problem with my ECM. Link to comment Share on other sites More sharing options...
stickedy Posted March 4, 2012 Author Share Posted March 4, 2012 Just follow the link to the USRM (http://www.ultimatesubaru.org/forum/showthread.php?t=76906) and download the attached file "ECU_repair.zip". Extract that ZIP file and you'll find a PNG picture wichich shows Q701! The number is printed on the circuit board, so you should find it. Link to comment Share on other sites More sharing options...
