lmdew Posted June 23, 2007 Share Posted June 23, 2007 Fixed. Just had to remove the bottom sill trim, loosen the two bolts and give it a wack with the board and hammer. I moved it back about 3/16" and it no longer rattles. Solid as can be. There is a little adjustment in just the latch plate, but I needed more. Anyone have the cure for the Rear hatch rattle on a 98 Impreza. There does not seem to be much adjustment in the hook and none in the latch. The bumpers are in good condition as is the seal. Am I missing an adjustment point, Thanks, Larry Link to comment Share on other sites More sharing options...
Legacy777 Posted June 25, 2007 Share Posted June 25, 2007 My 97 OBS is doing the same thing....I adjusted it a little bit....but sounds like I need to do something similar. Link to comment Share on other sites More sharing options...
lmdew Posted June 26, 2007 Author Share Posted June 26, 2007 I think the nut plate inside must be sealed or held in place with some adhesive. I tried to push it back a few weeks ago. I could only move the plate a 1/16" or so. It took a wood block and a good wack to get it to move (bolts loose while moving it). Link to comment Share on other sites More sharing options...
scdrtramp Posted November 3, 2015 Share Posted November 3, 2015 My rattle seems to be the "strong arms that support the hatch when open. I have tried a few things, but they are loose on the ball that bolts to the hatch. Will new arms fix this rattle??? THX in advance. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 3, 2015 Share Posted November 3, 2015 there's a lot of force on those - sure that's where the sound comes from? maybe you could wrap them with some thin foam or bubble wrap or ????, check the clearance, then close the hatch and drive - see if there's any difference? Link to comment Share on other sites More sharing options...
