CzarMohab Posted June 23, 2007 Share Posted June 23, 2007 I'm just full of questions, aren't I? OK this one should be simple. Recently, and usually when its colder (like morning or evening) whenever I hit a bump, or turn signal auto-returns, or sometimes just because, the high-beams come on! All by themselves. I'm figuring its the control switch; turning them on then off alleviates the issue until the next bump, but the last thing I need is to get pulled over for this. Could it be something else? Is it an easy fix? Czar "This car is getting annoying" Mohab Link to comment Share on other sites More sharing options...
Cougar Posted June 24, 2007 Share Posted June 24, 2007 I think you are correct about the switch. It seems the most logical point. I haven't done that job myself so I can't say how hard it is to do that. I don't think it is real hard though it may take a little time to do it. Hopefully just cleaning the contacts will fix this problem but you may have to replace it. Link to comment Share on other sites More sharing options...
