hatchsub Posted June 24, 2007 Share Posted June 24, 2007 hey which mark do i mark for the timing gun. There are three 10, 0 and 8. I kno that the timing is supposed to be at 8 degrees but there is not a definite line under the 8. 8 is kinda between two lines. The 0 has a very def mark though. So...what do i do. help quick would be great cause im in the mist of it right now. Link to comment Share on other sites More sharing options...
4x4_Welder Posted June 24, 2007 Share Posted June 24, 2007 If you have a timing advance knob on the gun, go ahead and set that at whatever you want the timing to be, and set it to the zero mark on the flywheel. Otherwise, set it to the 8BTDC, or you should be able to get away with 10º Link to comment Share on other sites More sharing options...
hatchsub Posted June 24, 2007 Author Share Posted June 24, 2007 Hey thanks...after posting i read in more detail HTKYSA and it told step by step which one/ones to mark. I marked them and all is well. Timing is set at 8 degrees Link to comment Share on other sites More sharing options...
