Legacy Outback Strut Spring Swap, Duh.
I have searched the forum already. I may be dim, but the answer eludes me.
For MY'97 Legacy Wagon Auto AWD, in my case:
Are Legacy Outback Struts a direct fit onto my '97 Legacy AWD wagon, using the original springs?
Specifically KYB GR-2.
These are a great deal, IMO, and they have sold a bunch of them:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170125720640
Is the seller OK?
Outback struts will work, but you might want to double check that eBay link. It says they are Legacy struts - not Outback.
I haven't dealt with that vendor, but did get good results with seller jdmwerks on a set of 4 GR-2's. Bought from seller performancepeddler but they sent me one wrong strut though they were good about taking it back.
Thank you all very much. Right, wrong link.
http://cgi.ebay.com/ebaymotors/KYB-GR-2-GR2-STRUTS-SHOCKS-SUBARU-LEGACY-OUTBACK-95-99_W0QQcmdZViewItemQQcategoryZ33590QQihZ006QQitemZ160129522534
Done bought and done. :clap:
Sounds good. Have you replaced struts before?
I see those are from jdmwerks13. That's where I got mine. I didn't receive any confirmation, tracking number, or anything (which made me nervous), but I did get the struts in good shape in a few days.
Yeah, but I'm getting the new clam-clamp type compressor now. Maybe 2.
Anybody ever replace tie-rod ends, ball joints, or other bits at the same time? (Since I will probably cave in for an alignment, due to the height change.)
I got a clam type compressor from harbor freight. It works well, but I don't use it anymore because it's too bulky, hard to get on the springs, and it's arms are sometimes in the way for the top hats. So I got that kind with the two threaded rods with the hooks/arms from Lisle.
I recently put some lift springs on my Outback and it did throw the camber off. I didn't replace any ball joints or anything at that time. Getting the alignment is the ideal thing to do I guess. At least for the interim, I just set it for zero camber by using a 12" long level against the wheel. It took a few iterations to zero out both sides. Subaru seems to give a fairly liberal camber tolerance though anyway.
