davis Posted June 28, 2007 Share Posted June 28, 2007 I posted a message earlier about this. I have a '01 Legacy GT. After getting the timing belt and head gaskets replaced and back from the dealer, the steering is making a whining sound and sometimes shudders when turning (way before the stops). I just talked with the dealer and they said that they think it is probably the Power Steering Fluid Pump. Does this sound reasonable to anyone? If so, how much am I looking at to have them replace it? Any chance any of this is caused by the work they just did? It seems weird that the steering didn't behave like this before. Thanks! Link to comment Share on other sites More sharing options...
nipper Posted June 28, 2007 Share Posted June 28, 2007 Yes. You can get a used one from a junk yard. nipper Link to comment Share on other sites More sharing options...
johnceggleston Posted June 28, 2007 Share Posted June 28, 2007 chech the fluid level, tension on the belt and its over all condition. Link to comment Share on other sites More sharing options...
porcupine73 Posted June 28, 2007 Share Posted June 28, 2007 Is the fluid level correct? Is it bled out properly so there's no air in the system? Is the belt in good shape and properly tensioned? Are the hoses kinked or bent or damaged or anything? It's kind of hard to kink them but since the engine was out... The service manual has some other tests you can do on the pump. If it is the pump, a new oem pump is not cheap, like $300. Overtightening the belt did mine in. According to the service manual, the pump internals are servicable, but I don't know how readily available the individual parts are. Maybe Subaru offers rebuilt pumps. Link to comment Share on other sites More sharing options...
Virrdog Posted June 29, 2007 Share Posted June 29, 2007 most likely just low fluid if you have not had problems before. Link to comment Share on other sites More sharing options...
