Gyoas759 Posted July 2, 2007 Share Posted July 2, 2007 I tried starting my 83 GL this aftrenoon and I'm not sure what happened. As usual it started and stalled out a few times before running. it started, stalled, started, stalled. (As is normal) But the third time I went to turn the key, nothing happened. No click, no crank, no nothing. The battery connection is good. I think the ignition coil is okay. I don't think the starter konked out. The fuses all seem fine. Any ideas? I'm sure it's something simple but I just can't find the problem. And I'm stumped because one second it cranked like it always does and now I'm not getting anything when I turn the key. Any ideas or advice would be very much appreciated. Link to comment Share on other sites More sharing options...
Cougar Posted July 2, 2007 Share Posted July 2, 2007 Clean the battery connections with a wire brush. Also check the fusible links for a loose connection. If that is ok then check the connector for the ignition switch for a problem. Link to comment Share on other sites More sharing options...
Gyoas759 Posted July 2, 2007 Author Share Posted July 2, 2007 Clean the battery connections with a wire brush. Also check the fusible links for a loose connection. If that is ok then check the connector for the ignition switch for a problem. Went over everything carefully. Found the starter connection was loose. VROOOM! thanks for the advice. Link to comment Share on other sites More sharing options...
Cougar Posted July 3, 2007 Share Posted July 3, 2007 You're welcome for the help. Glad you got it going. Link to comment Share on other sites More sharing options...
